Old 01-25-2004, 09:14 AM
wright51 wright51 is offline
Electical mystery
Yesterday, I had the following done on my son's 96 Taurus:
New Battery...New Starter and a New Alternator.
Now the radio stopped working and the speedometer/odometer does not function at all. What is the relationship between the work done and these problems? I can find NO fuse or relay that is common, in fact I can find NO fuse for the speedometer at all
Any help????
Old 01-28-2004, 01:37 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
On my '87 Taurus, the speedo is driven by a cable from the transaxle. Not aware if Ford changed this in any way, but I doubt they did. UNLESS you have the digital dash. Then it's a whole different story!
Who did the work? And does your car have the digital guages? (Did Ford even offer them as late as '96?)
Poke around under the hood, see if you can spot any wiring harness connectors that look like they've been pulled apart and maybe not pushed back together, all the way. You might find other loose wires, too.
Old 02-08-2004, 08:59 AM
amuizme amuizme is offline
Re: Electical mystery
Digital dash or not your speedo is electicaly driven by a speed sensor. I'm sure your problem is resolved by now, can you share the fix? I suspect either a connector problem as suggested or more common a bad ground..........
Taurus Dies Mysteriously the100thballoon Taurus | Taurus Wagon 19 11-04-2010 10:14 PM
1991 Buick Rivera Electical Problems KEVINS800 Riviera 2 02-06-2005 01:51 AM
Electical Problem dieselsdad Ranger | Courier 1 01-09-2004 06:35 AM
marvel mystery oil a mystery berkcamaro Camaro Discussions 0 08-16-2003 11:06 PM
