Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 01-24-2004, 07:59 PM
tony urresti tony urresti is offline
engine vibration when stop light
Help needed!
96 saturn ls automatic trans.When the car is in gear vibrates,we check for vaccum leaks .none.new plugs and wires,good compression ,egr valve closes,no check engine light.new idle control.motor mountings new.tps ok. is a fast vibration no like a miss en the engine,feels like a broken fan in early cars
Thanks
Old 04-12-2004, 10:45 PM
kicknbutts kicknbutts is offline
Re: engine vibration when stop light
check for vacuum leak between #2 and #3 cylinder on intake gasket. gasket may be bad or warped intake. also check to see if you have the current calibration on PCM.
