4age turbo
does anyone sell a turbo kit for a 4age? if so where can u purchase it.
Use RX-7 FC/FD standard turbo kits (used part)
remeber don't use 0.8 mm gasket kit on it . change the injector (bigger cc) add oil cooler & bigger radiator Change yours fuel pump (Example Bosch) add a feul managment CPU note : use the RX7 front Disk brake system , if you can .... btw you do not need a intercooler for this mod ....if you really want it , just use the Levin top intercooler. for more info & detail go here http://www.billzilla.org/4agmods.htm |
Re: 4age turbo
Depends how much boost you're running. <6psi, no IC. Otherwise stuff the biggest FMIC you can fit in the front.
depends what 4age it is... year? (cam cover red, blue, silver, black top?)
