Old 01-24-2004, 04:33 PM
Terry Mer Terry Mer is offline
99 suburban fuel pump blowing fuses
I have a 99 suburban that blew the 20 amp fuel pump fuse. I replaced it and it ran okay but I changed the fuel pump for safety. It ran for a few days and blew again. I fixed a loose chasis ground and changed the fuel pump relay and it ran okay for a few days then blew again. Suggestions???????????
Old 06-18-2004, 09:10 AM
Alderman5 Alderman5 is offline
fuse blow 99 surburban
Did you ever get any answers regarding your problem. We are having the same problem with ours. Have replaced the fuses now we are trying to trace down wires.
Old 06-30-2004, 09:25 PM
777stickman 777stickman is offline
Re: fuse blow 99 surburban
The ONLY thing that blows fuses is a direct short to ground on the power side. So, you need to look for a chaffed power wire from the fuse to the load (relay or pump).
Good Luck..........Steve
Old 07-02-2004, 01:41 AM
flht flht is offline
Re: 99 suburban fuel pump blowing fuses
The wire harness that plugs into the fuel pump assy (to pump and gage) inside the tank is corroded and shorting out. four wires two to pump Gary one on my unit was trashed. Clean it up with small file and plug it back in I had no luck in finding a replacement but mine works fine 5000 miles in a month and going strong. PS I hate gas prices (LOL)
Old 07-02-2004, 07:12 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: 99 suburban fuel pump blowing fuses
Usually on that model, the gray 12v feed to the pump (inside the tank)will melt the insulation and the warm wire will rub the ground side until the insulation is gone and cause a direct short to ground and blow the fuse
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
