Old 01-24-2004, 01:20 PM
mo92 mo92 is offline
Send a message via AIM to mo92 Send a message via Yahoo to mo92
Installing exhaust on a stock 99 Civic
When putting an aftermarket exhaust on a 99 civic Si do you have to cut out alot of the bumper to get the muffler to fit?
Old 01-24-2004, 02:45 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Installing exhaust on a stock 99 Civic
no, none at all
Empty Pockets Racing Member #1
Old 01-24-2004, 08:19 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Installing exhaust on a stock 99 Civic
Originally Posted by GScivic7
no, none at all
Agreed. With pretty much ANY exhaust system you install on your Civic, you should NOT have to cut out any part of the body or bumper for it to fit correctly. It should just simply bolt in in an hour of time at most.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-25-2004, 03:16 AM
chimchim chimchim is offline
What if the bolts are all rusty and stuck... and WD40 does NOT do the trick and I don't have access to an impact gun. Any suggestions?
The flange seems to have little springs on the bolts, does that mean it's gonna be really hard to put the thing back together?
Old 01-26-2004, 12:46 AM
Black99Ex Black99Ex is offline
Send a message via AIM to Black99Ex
The best trick to get off rusty exhaust bolts is an acetylene torch... wear gloves... and heat up the nut for a lil bit.. and use a wrench, or air ratchet to get it off... works like a charm everytime
nope its really easy to get them back on, the spring is just to allow that section of the exhaust to have some flexibility
hope it helps!
Old 01-26-2004, 01:10 PM
Re: Re: Re: Installing exhaust on a stock 99 Civic
I've heard of this before... so do I torch the bolt or aim for the threads (like where I spray WD40) or should I torch the flange?
Do I let it cool a little before I wrench it?
Is the theory behind this that you expand the bolt with heat to break the rusty seal, and then it should be able to go?
Oh yeah, and what's the best way to get the rubber hanger off the old exhaust and then onto the new one? Just brute force?
Old 01-26-2004, 01:24 PM
Cali Guy
Re: Re: Re: Re: Installing exhaust on a stock 99 Civic
Vasaline. Works like a charm and with little effort at most. Just make sure you wipe it all off before you put them back on (including inside the hols of the rubber piece that slides over the metal hangers), otherwise they will be easy to slide back off under vibration.
hessemer69 on AIM
Old 01-26-2004, 01:48 PM
Torch the nut on the end of the bolt, not the flange itself really.. and take the nut off immediately... and watch out obviously, cuz its going to be hot, and i just brute force the rubber hangers off.. vaseline should be good tho as someone said above.
Old 01-26-2004, 05:56 PM
GScivic7's Avatar
WD40 also works great on the rubber hangers
Old 01-26-2004, 08:50 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
PB Blast works much much better than WD 40 to help free stuck bolts
LS1 RX-7 Zoom Zoom
Old 01-26-2004, 10:07 PM
GScivic7's Avatar
we're not talking about bolts though, we're talking about rubber hangers
Old 01-26-2004, 10:34 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I used good ole fashion leverage to get my bolts off. I slipped a pipe over my socket and just pryed
But yeah PB blast works better than WD40.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
