Old 01-24-2004, 02:22 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
relocating amp
I was thinking of relocating my amp in my car. I want to move it below the rear seats, so you would literally be sitting on the amp, although I would build a box around the amp with a vent, and fan for the hot days.. but is there really enough space under the seats for that? or would I be better off just wiring the amp up on a rack bolted to the underside of the top of the trunk (like a tray |_amp_| ). which would be better? It's a Coustic 450 watt amp, and it looks nice so if I do do an under seat on, I want to be able to lift the seats and have a lexan/plexiglass top with some lights on it for when I'm showing it off. and possibly make the box a bit bigger than required in case I get a newer/bigger amp. but is it possible to hide the amp under the rear seats in my accord?
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 01-24-2004, 02:43 AM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: relocating amp
Yup, i have seen it before. But i do not know wha textend they had to go through to make it work properly. But i have seen it done on an accord, bebeave it was a 99 2 door V6 if that makes any difference.
Old 01-24-2004, 02:10 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I wouldn't do it. Space under there is minimal at best and wouldn't have enough clearance for pretty much most amps. Also keep in mind with the heat the amp generates, probably not good having it there since the fuel pump system of you car is located under the rear seats. Heat and fuel don't go well together.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-24-2004, 06:00 PM
looking4_12s_run looking4_12s_run is offline
Re: relocating amp
I wouldnt worry too much about the fuel and heat. A Coustic amp doesnt put out enought heat to cause much problems but hey, why chance it.
If you put your amp under the rear seats it will overheat pritty fast. Even if you create a box for it, you wouldnt be able to easily bring down the tempeture of your amp. For air cooling to work you need a fan pushing cool air into the area and a fan taking warm air out. On top of it, these fans would have to be the right strength and size. All this means that your amp box would probably be too big (high to be specific) to satisfy its confine. You would have to either hollow out the seats or cut into the chasse (bad idea) or both, just to get the right clearance. And... even if you do all this your amp still might not work at its best. (amps run better when they are cooler).
My suggestion would be to put it under the top of your trunk door. If you wire it nicely along the sides and down the hinges you could have a nice look too. If you have a hatchback you can put it under the roof (right on top of the heads of rear passengers) and wire it down the sides to the back (very nice). If you choose to go with these methods make sure you use some sort of meterial between the amp and roof that will take some of the vibration/shock (it will help the life of your amp).
Hope that helped you make your decision.
For those who dont get us, go spend 50 grand on your status symbols.
For half the price, we'll be passing you by in custom style at high speeds, expressing our selves and teaching the world not to conform to its corrupt ideals of rich will be rich and you should buy this.
We will demonstrate the intelligence of desire and swim in the success of doing what you said we couldnt.
Screeachhhhhhh.... and im gone.
Old 01-24-2004, 08:26 PM
Cali Guy
Can't cut into the body/chassis directly under the seats, that's where the gas tank is at of which the fuel pump sits almost inside of.
killah_xft, what about mounting your amp UNDERneith the floor board in the trunk, where your spare tire is located at. There should be enough room between the spare and the very back side of the space down there closest to where the bumper is at. It's cool in reguards to tempature issues, not visible to anyone, saves space from other places you'd otherwise mount it, and out of the way. That's where I have my amp JBL 4-channel amp mounted at, and I even still HAVE my spare down under there too! Look into that and do some measuring around under there to be sure your amp will fit. It's a guaranteed good spot. I think so at least.
hessemer69 on AIM
Old 01-25-2004, 03:35 AM
Re: relocating amp
I'll take a look at that sometime, but right now it's to friggin cold out... Just thinking of Ideas to work on during the spring.. want to get my sound system squared away how I want it before I get much into the engine mods and everything this summer.
Old 01-25-2004, 03:06 PM
Re: relocating amp
On the accord the trunk floor board sits right up against the chasse and the only open space is where the spare goes. On my old civic I agtualy put a sub in there. It is a great place to put your amp but bye bye spare. (I replaced my spare with a air pump for emergencies) -- cant have it all.
Old 01-25-2004, 04:39 PM
Cali Guy
Re: Re: relocating amp
Odd, I have BOTH my "17 x "12½ size amp, and my spare still there under the floorboard in the trunk. Only alteration I had to make was relocate my jack to under the passenger seat. I'll have to post up a pic to prove this I suppose.
hessemer69 on AIM
Old 01-27-2004, 04:12 AM
Re: relocating amp
still colder than fuck outside... just plans for the spring/summer.
Old 02-23-2004, 04:19 PM
Re: Re: Re: relocating amp
I had to tell you what a great job you did on your interior. Its not too little or too much.. really really sweet man.
I believe some models have some extra space next to the spare. That would explain it.
Old 02-24-2004, 01:53 PM
Cali Guy
Re: Re: Re: Re: relocating amp
Most def. Thanks man!
hessemer69 on AIM
Old 02-25-2004, 11:32 PM
EclipseACCORD's Avatar
EclipseACCORD EclipseACCORD is offline
I have a nice link for you!
But it requires much customisation!
Here goes: Accord backseat
CAI sounds so good.... but not as good as Eclipse I.C.E.
Old 03-06-2004, 06:39 PM
Re: relocating amp
nasty cool and F###ing original... Very sah-weeeet
