Old 01-24-2004, 01:50 AM
crxsirII crxsirII is offline
Question 92 zc dizzy
Does a 92 zc dizzy have to be hooked up to an obd1 ecu?
Old 01-24-2004, 08:54 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: 92 zc dizzy
If its a 92 dist, it should run on obd0, but you may have to use the crank angle sensor from a 1g teg. That's what I had to do...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 01-24-2004, 09:09 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
a 92 dizzy most definltely needs to be run on an obd1 ecu..there's no way around.. the gears inside have a different number of teeth I believe.. (something like that )..if you want to run it obd0... grab and 88-91 ecu..
SOLD!
Old 01-24-2004, 09:13 AM
4GZChatch's Avatar
Re: 92 zc dizzy
that's not true. I am using a 94 dist with my z6 swap, and it works fine, as long as you rewire it right. The internal crank angle sensor is different, i think, and that's why I ended up using the separate sensor on mine...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
