Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-24-2004, 12:57 AM
2003rsx18 2003rsx18 is offline
Rear Breaks Shake !!!yikes!!!
my friend has a 91' 240sx hatch. when he drives fast and then tend to break the breaks start to shake and then makes this funny noise...the car shakes! WTF is wrong with his car??? oh he drives a auto. so when the car shifts it jerks ONLY when it shifts from first to second gear...any thing please help!
Old 01-24-2004, 04:42 AM
vsiev vsiev is offline
Send a message via AIM to vsiev
Re: Rear Breaks Shake !!!yikes!!!
I say his rotors need to be resurface....What size tires does he have? I had a car once that had smaller tires in the front and it shakes when i brake...but that was the front of the car not the back.....Just another option to the problem
Old 01-24-2004, 07:49 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
buy new rotors, before you do inspect them on the car, just take one tire off and look at it, if its bluish in some spots that means it has heated up real bad and been abused. Also feel up and down along the rotor surface, from inside hub to outer edge... it might feel like it has grooves in it and not flat....... those are the common flaws you can visually inspect yourself pretty easily to see how the rotor is.
Old 01-24-2004, 09:26 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
Has he LOOKED at the brakes yet?
BTW does the car jerk from first to second only when hes flooring it or is it all the time? Well, either way sounds like an abused automatic.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 01-25-2004, 02:19 PM
my friend does abuse his car but when he's not it still jerks from first to second ALL THE TIME!
Old 01-25-2004, 03:30 PM
billclinton's Avatar
billclinton billclinton is offline
i had all those problems on my moms minivan after i seriously abused it for like a month, i replaced the front rotors and the tranny was fucked up and didnt shift right from doing neutral drops.
shinrekka 1 : i think the carburater needed to be rebuilt and were gonna drop the gas tank
NoLlieSkillz : its called
NoLlieSkillz : neutral drop at redline
Old 01-25-2004, 05:45 PM
xXxSleeperxXx xXxSleeperxXx is offline
tranny's slippin sooner or later it will stop shiftin
Old 01-25-2004, 11:57 PM
tranny slippin' how u fix that? wat should he do about the jerk from 1st. to 2nd? how can he fix this shit!
Old 01-26-2004, 12:09 AM
for my friends 91' 240sx wat kinda of rotors should i get? and how to fix that damn jerk from first to second!
