Old 01-23-2004, 07:35 PM
rslack rslack is offline
98 Chevy S-10 - won't start - fuel pump?
I have a 98 Chevy s-10 that has been running fine. I was driving it all day. I made a half hour stop, came out to start it again and it wouldn't start. When I turn the key, it wants to start and sounds like it's turning over put won't actually start. I don't here the fuel pump like I usually do when I start it. I checked the fuse to the fuel pump but that seems fine. Could it be that I need to replace the fuel pump? Anyway to tell if it is the fuel pump before replacing it?
Appreciate your feedback-
Old 01-23-2004, 08:47 PM
BUGPAK1600 BUGPAK1600 is offline
Send a message via AIM to BUGPAK1600 Send a message via Yahoo to BUGPAK1600
Re: 98 Chevy S-10 - won't start - fuel pump?
Dear rslack a quick way to check your fuel pump is to make sure it is getting voltage, do this by using a digital voltage tester on the wires going to the fuel pump if they are accessable. You might also want to check the fuel filter and lines, because that is a lot cheaper. I am not sure but some GM models also have inline fuses to some devices, which aren't located in the fuse box, to find this out buy a service manual for your truck at any local auto store, it is the best 20 dollars you can spend!!!!
Old 01-24-2004, 06:02 PM
Fox_Rocks Fox_Rocks is offline
i suspect that your fuel pump is stil working if you can hear it cycle like you said....did you check all your fuses or just the fuel pump one? i wonder if your EEC or ECM fuse it done....anyways that would be a long shot. the easiest thing to do is check your fuel pressure on the fuel rail on your engine. try those for now, let me know.
1991 Chevy S-10 Ext. Cab
4X4, 4.3L TBI V6.
-Competition Camshaft, Ported Heads, Bored .40 Over,
Completely Rebuilt (everything), Roller Lifters, K&N Filter,
MSD Wires, Jet Performance Chip, B&M Shift Kit,
AirRaid TBI Spacer, 3:42 Posi Trac, 2" Lift,
American Racing Wheels, BFG All Terrain Tires
Old 02-16-2004, 10:34 AM
NovaRod NovaRod is offline
Your symptoms seem similar to what we are working on with a '96 2.2L.
Check the following thread and if you find anything, let us know. we will do the same. Thanks!
NovaRod
http://www.automotiveforums.com/vbul...d.php?t=188705
Old 02-27-2004, 06:36 PM
wutziznuts wutziznuts is offline
Yup, your fuel pump is shot. I have the same truck, and literally the exact same thing happened to me. I could no longer hear the fuel pump and she wouldn't turn over, but it would still crank. The fuel pump is an in tank and sending uniy combined. The whole unit costs anywhere from $400-600 depending where you buy it. Sorry man, I know it sucks!
2000 Crown Interceptor won't start fuel pump won't run chrisstag Crown Victoria 16 01-30-2007 04:00 AM
96 Yukon Won't Start. Fuel pump is priming, Spark plugs are sparking. HELP Jimbeamrye Yukon 4 03-27-2005 08:00 PM
won't start/fuel pump dbestnindy Jimmy 4 08-12-2004 12:20 PM
Won't start... fuel pump??? monkeycb Malibu 3 04-03-2004 07:37 PM
