Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-23-2004, 06:15 PM
alphalanos alphalanos is offline
hub compatability
i have an 02 Lanos hatch and i want to put 17x7's on it. the rims are the correct lug pattern, but my hubs have no bolts to mount them onto, because the stock rims mount by means of screw-in type lug nuts. i think i need an adapter that will accept just plain nut type lugs. where do i get them?
96 EJ6. Future home of boosted B18C1.
Old 01-23-2004, 06:22 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Re: hub compatability
The shop selling you the wheels should have provided you with the correct hardware that matches the wheels and the car. Check with them or the wheel maker to see what hardware works safely.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 01-23-2004, 06:47 PM
i forgot to say that im buying them off of a friend who has a 90 accord....
Old 01-24-2004, 07:58 AM
If they are factory wheels on a Honda now, there's no way they will fit safely. The Accord has a 1-114.3mm bolt circle an your car is a 4-100mm. They may work if it's an aftermarket wheel with multiple bolt circles and the correct center rings. The big problem is going to be the center bore. The hole in the back of the Honda wheels is going to be almost a full 1/2" larger than your hub. The wheels need to center on the hubs, not just the lugs (this is called hub-centric). It can cause not only vibration, but also lug/wheel failure. The 'nose' of the axle has to fit snug inside the back of the wheel's centerbore.
Grant
fax# 574-236-7707
'95 noise stops when in put in 4 high HUB??? lizzye71 F Series 3 12-23-2009 06:51 AM
'95 noise stops when in put in 4 high HUB??? lizzye71 F Series 0 12-21-2009 07:16 PM
Manual locking hubs Danielcarrillo1 Rodeo | Passport | MU 2 10-01-2009 03:16 PM
04 Cavy Wheel Hub Sensor atlas86 Cavalier Problem Diagnosis 0 09-08-2009 11:46 PM
Another 2004 Alero hub assembly and front brake question. Seattle Al Alero 3 02-20-2009 07:38 AM
