Old 01-23-2004, 03:56 PM
1SickZC's Avatar
1SickZC 1SickZC is offline
Send a message via ICQ to 1SickZC
adjusting valeas... need help
just have to clearify if the pistins gotta be at top dead center for all the valves , or what.... need help asap... thanx
Old 01-23-2004, 11:49 PM
BullShifter's Avatar
Re: adjusting valeas... need help
Yes, you must adjust each set a valves with it's piston at TDC so you will be turning over the engine for each set.
Can't get any easier than this:
http://www.binghamtonlife.com/manual...es/91-6-30.jpg
http://www.binghamtonlife.com/manual...es/91-6-31.jpg
Old 01-25-2004, 12:45 AM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
SCREWW ALL THIS #$%^#$^ SHIT AND GET SOMEONE TO PROFESSIONALY INSTALL THEM OR U ARE GOING TO BLOW A ROD OR MESS UR ENGINE UP
Old 01-25-2004, 01:03 AM
lilol89crx lilol89crx is offline
lol this guy always says take it to the pro! were here too learn, not take our cars to the pro's
Old 01-25-2004, 01:14 AM
Re: Re: adjusting valeas... need help
There is nothing to install with a valve adjustment. If you can't follow direction's step for step then do not attempt, but most people learned to follow instruction in 1st grade . . . . valve adjustment on a D series is as easy as can be, at least for me.
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 02:28 PM
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
Need help with alignment Adjustments for a 72 caprice JohnnyT Caprice 4 08-12-2004 04:14 PM
Need help adjusting Headlight integrasedan Integra 0 11-14-2003 02:11 AM
Need help adjusting Idle on '89 CRX Marc-OS '71-'87 Civic | CRX 2 12-29-2001 06:44 PM
