All turn signals quit. Heater Fan stopped.
My turn signals all quit at once. checked fuses. replaced bulbs and flasher unit. Does anyone have any answers? Would appreciate your input./ Also at the same time the fan for the heater quit. I have checked the fuse and replaced the resistor. No help there. HELP!!!! this car is driving me bonkers...
Re: All turn signals quit. Heater Fan stopped.
Anyone have an answer to this? I am experiencing the same thing on an 88.
Do your flashers work? You may have to break your column down and with a volt meter, start checking for voltage to the turn signal switch. If you got power to it, turn the left and right blinkers on and check for voltage going out. If no volts are leaving the switch, theres you answer, is voltage is leaving it, I'll post with more later. The heater fan is not connected to the signals, although you may have a bad/loose ground which can cause both these problems. A short, even a screwy ignition switch can cause this. I'd check the grounds, mainly under the dash. Check all the wiring real good under the dash on the steeing side, then the column. Check for voltage with the flasher as well. I hope someone else will post with help cause this info is lessons learned from the 93 we have. I can't see it being much different though.
The flashers do work. I was looking for grounds under the hood and took off a couple of screws into the firewall , sanded them down and put back but to no avail. I also removed the lower steering column shroud and was just looking and playing with wires. My mother said sometimes she used to bang the steering wheel or adjust the tilt up and down and both turn signals and heater would work. I do own a voltmeter but only know how to test battery voltage. Any help would be appreciated.
I had the same problem ,change the turn signal assembly its broken with a short circuit on it.Once you change this everything should turn to normal .
