Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-23-2004, 07:23 AM
DCNo07 DCNo07 is offline
someone double check
alright heres the deal, i just got some money from insurance and selling my car sterio so i have about $1400 to spend on performance after gettin my car fixed. i have a list of parts and a plan but i dont know prolly nearly enough to be doin what im doing.... so i just need you guys to check my part list... i have i/h/e -Apexi v-afc--and im getting - skunk2 or crower stage 2 cams- valve springs/valves- cam gears- fuel rail - fuel pressure regulator - underdrive pulleys - clutch.... anything else i will need... mostly haveing to do with the cams since they will be the most major mod....i shouldnt have to replace my stock retainers should i? and my buddy is dyno tunning my car once everything is done if that makes a difference. i shouldnt need a upgraded fuel managment system after all that should i??? oh and i have a 97 gsr ....
Old 01-23-2004, 02:02 PM
Slickster007 Slickster007 is offline
Re: someone double check
my opinion...I think the underdrive pulleys are a waste of money along with the fuel rail. The stock fuel rails on our cars can handle up to 350 hp easy. I'd go with the crower 403 cams and while you're upgrade your vavletrain might as well get titainum retainers. I don't think you'll have enough money for the clutch, especially if you take all of this to a shop. You'll pay 300 just for labor, or more! I'd go with the B&M FPR also...much cheaper and just as worthy as the AEM one. Good luck!!
My website with pics and info of my car!
FS:Torque converter - $100, cruise control sys. (actuator, cable, computer) - $50, AT intermediate shaft - $50......etc.etc...finished with auto to manual conversion and now I'm selling leftover parts.
Old 01-23-2004, 03:11 PM
ibsixubnine03 ibsixubnine03 is offline
Send a message via AIM to ibsixubnine03
thats wut i thought, thats not quite enough money for all the parts plus install...
Old 01-25-2004, 05:39 AM
ok...i took off a few things from my list so now its just stage2 cams -valve springs -valves-cam gears- fuel pressure regulator- my engine should run fine without retainers right? i jsut cant take it past redline.... 97 gsr i/h/e - v-afc
Double checking the thermostat BlenderWizard Silverado 3 07-15-2005 05:18 PM
Crankshaft sensor - double check it Shafted Grand Cherokee | Grand Cherokee SRT8 1 08-23-2004 10:09 PM
B16A Vac line Hookup Double check Mojoe '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-06-2004 08:25 AM
Just double checking Civic Jim '88 - '91 Civic | CRX | Wagon | Shuttlee 10 05-30-2003 12:27 PM
