Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-22-2004, 11:15 PM
RaulLince RaulLince is offline
running hot b2200, In winter!
Just put rebuilt head on my truck new thermostat, new coolant. But My truck fluctuates in tempature (all in the normal range) under a load going up hills on the interstate. I'm at a loss. New radiator cap, and the motherfucker keeps heating up. At idle it does not do it but at speed( 60 70 mph) temp guage starts going up and down never below middle. Does your truck run in the lower 1/4 of the guage or in the middle? This is my first long drive since the new head so i am confused. Any advice out there. Raul
Old 03-05-2004, 05:45 PM
Mikey350D Mikey350D is offline
My truck is doing same: replaced fan clutch, thermostat & water pump and truck still heats up at highway speeds. Suspect head bad.
Rad pressure check was good.
Performed block check (combustion gas in rad) when motor was cool.
Pulled head off today: cracks between plug holes and valves.
You need to have your head work done by a quality shop; who can (heat) straigten, line bore and not over-shave (or shim).
I replaced original b22 head with b20 head to get rid of hydra-lifters.
Old 03-11-2004, 02:51 PM
markbaham markbaham is offline
Re: running hot b2200, In winter!
I had a similar issue. Mine only overheated when I went above 50mph. My problem was simple. My truck sat for about 2 months before I fixed it. In that time, the radiator got clogged up. It would not overheat while idling for an hour, but as soon as I drove it down the road it went hot.
Old 04-09-2004, 09:26 AM
brownt brownt is offline
I had the same problem, I upgraded my thermostat to the best grade NAPA had & my overheating on the highway stopped.
1999 cherokee 4.0 running hot....sorta wkumale Cherokee 11 09-15-2010 09:05 AM
Isuzu Rodeo Runs HOt WNathan67 Rodeo | Passport | MU 1 07-03-2010 08:29 PM
88 B2200 running hot bigbird0001 B-Series/Bravo/Bounty/Drifter 2 03-20-2007 01:45 PM
Engine running hot?...Front Wheels hot? mbirge Wrangler 2 11-08-2005 10:10 AM
97 3.0 running hot after Interstate run Scoopo Taurus | Taurus Wagon 5 06-15-2005 09:16 AM
