Old 01-22-2004, 08:45 PM
TPyles TPyles is offline
Quickie on fuel pressure reg & hard warm start
I have read a lot on the 5.3 hard start when warm. I had mine in a couple of months ago and it wouldnt hard start while at the shop, mostly because it was cold. There are no computer codes or trouble lights. I pulled the small vacume hose off the fuel pressure regulator the other day and some gas dribbled out...Does this mean the fuel pressure regulator is bad?? The truck is a 1999 Silverado 4x4 with about 180,000 miles. Other than the hard warm start it runs like a top!! I appreciate any insight Thanks for the help.
Old 01-27-2004, 07:46 AM
brandon093 brandon093 is offline
Re: Quickie on fuel pressure reg & hard warm start
I am having the exact same problem with my 99 5.3 Silverado and I can't figure it out. I did replace the Fuel Pressure Regulator and I have had no luck yet. Someone told me that it might be a bad relay switch that is telling the PCM that my oil pressure is too low to start. Still troubleshooting that idea. If I figure it out I will let you know.
Old 01-28-2004, 11:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Quickie on fuel pressure reg & hard warm start
A fuel pressure regulator that is leaking at the vacum port is considered faulty and can cause hard starting.
Also a dirty throttle body can cause a hard start warm
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-10-2004, 02:59 PM
jdstone jdstone is offline
MIne had to crank 3-5 seconds to start (hot or cold) and had rough idle during the last few weeks. Fuel pressure was normal at about 50 psi. I had gas in the vacuum line also. There should be no gas there! It means that it is sucking gas thru the regulator and into the intake causing an excess rich mixture. Changed the easy to replace $50 regulator and now it starts instantly and has perfect smooth idle! Thanks to the messages on the forum that helped diagnose the problem quickly!
Old 08-20-2004, 07:45 AM
mastanga mastanga is offline
hard start when warm and rough idle 1999 4.8 silverado
My 1999 4.8 starts fine in the morning but once I have run it for a while then let it sit (even for hours) it is hard to start and idles rough until I take off. Sounds to me from all the notes that it is the fuel pressure regulator. Is the regulator next to the intake under the Vortex shroud? Thanks
Old 08-21-2004, 10:08 AM
1999 silverado 4.8 hard start rough idle
I changed the fuel pressure regulator ($70 for the little thing) and it fixed the problem. I noticed when I pulled off the vacuum line that there was a lot of gas in the line. I want to thank everyone for the help this forum is great.
Old 03-26-2012, 01:09 PM
rocky3d rocky3d is offline
This is a very old thread but I am having a similar issue with a 2004 Suburban. Starts great when the weather is cold but when its warm weather its hard to start, usually takes 2 to 3 tries.
I have cleaned out the throttle body and replaced the fuel pressure regulator, fuel pressure seems right at about 50 psi. Wondering if anyone might have another suggestion? I was hoping the new fuel pressure regulator would fix it like most of the posts say it did.
Thanks,
John
Old 03-26-2012, 08:28 PM
j cAT j cAT is offline
the pressure spec is 53-62psi. on a ignition on cycle and engine off , the pressure should rise to 60 psi. if lower its saying the fuel pump is weak.
when the engine is running the pressure must be at or above 53psi. if not at least 53psi . you have pump problems.
when it gets to 50 psi this is the threashold of no start. depends on pressure guage being accurate. one drop/shock it will need be calibrated.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 03:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 07:32 PM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 03:01 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 07:12 PM
