Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-22-2004, 05:54 PM
zoomzoomzoom zoomzoomzoom is offline
Angry turn signal 2000 mali
were having problems with turn signals they wont work and clicking from dash stops .asked parts store if the 2000 malibu had a flasher said i did not.checked all bulbs and wires any suggestions .did i get bad info can anyone please help i hate people that dont signal now im one of them.
turn signal and clicking does work when they want to not all the time
Old 01-24-2004, 08:40 PM
99ssconv 99ssconv is offline
hey zoomie, next time it acts up try smacking on the dash just above the hazard switch, if they come back on then replace the hazard switch, the flasher is built into the hazard switch.
Old 02-06-2004, 10:29 PM
Re: turn signal 2000 mali
hey it worked now im trying to figure out how to remove hazard switch does the wood grain panel just pop off or is there screws somewhere thanks again for all the help
Old 02-07-2004, 07:33 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: turn signal 2000 mali
The panel should just pull off.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-12-2004, 11:11 PM
Harryc8786's Avatar
Harryc8786 Harryc8786 is offline
Send a message via AIM to Harryc8786
I drive a 98 and messed with my bulbs, blew a few fuses, so then i put the stock bulbs in. Changed fuses, i think they worked a while. But a few hours later the parking lamps work, but no turning and hazards? what do you think i should do, my turn signal fuse blew i changed it still no luck...i made sure the wire was connected to the hazard button and still no luck please help
Old 10-15-2004, 08:06 PM
Dalt10 Dalt10 is offline
Mine just started acting up. I guess I'll change the switch.
Old 10-25-2004, 08:01 PM
Took it to the dealer Saturday.They changed the hazard switch. Turn signals work fine now. No charge, the fix was under warranty.
Old 10-26-2004, 06:34 AM
treeman5 treeman5 is offline
It's actually a recall on the switch...for those of you who don't want to wait for the dealer to put it in...I did mine for $29 and 5 minutes of my time.
Old 10-23-2005, 12:05 PM
mark7tenor mark7tenor is offline
I removed and reinstalled the same hazard switch and I've had no problems for two weeks so far. I did rub some graphite (pencil lead) on the contacts, which may or may not have helped.
Old 11-05-2005, 11:35 AM
garync1 garync1 is offline
I have a 97 malibu and started having this problem.. Now I know what to look for. I did know there no flasher or more that it was not a replacable part.. But it clear now that there really is and its the hazzard switch.. Thanks..... I did also notice when I engaged the flasher my turn signals would work after. I always have done this trick before to test my external flasher on other cars.. I do like this malibu it came with my wife of 2 years got her a mini van and I drive the malibu to work.. i like it so much now that i will most likley get another one or another GM with the same motor.. Its one tuff machine.. my wife before we met drove the thing over 30,000 miles with out changing the oil I saw here quick lube sticker and checked the milliage and there was over a 30,000 mile gap there.. I asked her had she had the oil changed between that time and she said no!! but the oil light came on and I added some to it every time it came on.LOL I finally changed it and this thick stuff came out.. Yes there was sluge but I ran some light motor oil through it 5w20 for 100 miles 2 times and switch to synthetic motor oil it had a little bearing noise but still runs quick and strong. smokes a little on quick take off but nothing to unusal with a car that has 135,000 miles on it..If she took care of it it would most likey have seen 200,000 miles but its still going it could make it... I only drive it 16 miles a day back an forth to work so it will be long time before that happens if I dont get a newer one first..I work on cars on the side and never seen one with a tough motor like this..30,000 miles without chageing the oil..INSANE
2000 Rodeo - no pwr windows, rear wiper, ac/heat, turn signals, ... ShanerX Rodeo | Passport | MU 8 09-17-2010 08:45 PM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 06:20 PM
Problem with turn signals 2000 Alero juicydog42 Alero 6 06-05-2008 10:05 AM
Turn signals 2000 Trooper trooperbrett Trooper | SLX | Bighorn | Wizard 4 05-24-2007 07:12 PM
