Old 01-22-2004, 04:09 PM
fingers3707 fingers3707 is offline
02 Sliverado No power steering/brakes
I have a 2002 Silverado 2500HD 8.1 (8100) crew cab with the allison tranny. 16K miles.
Today the power steering/ power brakes quit working all of a sudden. Now the truck wont rev past 3000 rpm. The surp. belt is good and truck runs well still and drives fine other then no power streeing/brakes.
Anybody heard of this problem? Any remedy??
Old 01-31-2004, 02:18 PM
dretep1 dretep1 is offline
Angry No Brakes/ps
I can tell you this, today, 1/31/2004, I was making a sharp right hand turn and had no choice but to turn hard lock against the pump as uncoming trafic was coming right at me.
I'm from the old school that taught us never to crank those wheels as pumps could be blown sky high!
I have a 2500- 6L (2000) with a full snow plow.
After the turn I was shocked to find out that I had no power steering and upon first braking that I had none of those either.
This one really puzzles me as the Serpentine belt is fairly new and the both cylinders for the PS and master brake are full.
I shut the engine off and restarted and still no PS or brakes.
I need this in the middle of Winter with a full plow on and I haven't the foggiest.
Perhaps something to do with a relay, a power vacuum, or air pump?
Lost in the snow drifts.
Logger
Logger
Old 02-01-2004, 12:52 AM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: 02 Sliverado No power steering/brakes
cant help with the PS and PBs, but was the truck in park or nuetral when it wouldnt rev past 3000 RPM, or was it in drive? The computer wont let you rev past 3000 in P or N.
Old 02-01-2004, 07:03 AM
Re: Re: 02 Sliverado No power steering/brakes
Some questions have come up and I appreciate it.
The vehicle was in drive and I was making a right hand turn from a gas station onto a highway.
Then all went loose! No brakes, no power steering and with these major losses . . . NO idiot lights came on!
Old 02-03-2004, 11:01 AM
I did find out that NHTSA has started an investigation on this defect. If you have a chevy truck and it is around the 2000 model year, 2500 or 3500 series and the power steering pump shaft broke leaving you with no brakes or power steering that you might want to actively pursue the details as listed below. So far I have gotten GM to pay for the part which alone is over $300.00 bucks.
NHTSA Action Number : PE04004 NHTSA Recall Campaign Number :
Make : CHEVROLET Model: C2500
Manufacturer : GENERAL MOTORS CORP. Year : 2000
Component : SERVICE BRAKES, HYDRAULIC
Date Investigation Opened : January 8, 2004
Date Investigation Closed : Open
Summary:
NHTSA HAS RECEIVED 19 REPORTS FROM OWNERS OF GENERAL MOTORS 2500/3500 SERIES PICKUP TRUCKS ALLEGING A LOSS OF POWER BRAKE AND/OR POWER STEERING. THESE REPORTS CLAIM FRACTURING OF THE HYDRAULIC PUMP SHAFT IS THE CAUSE FOR THE POWER ASSIST LOSS. LOSS OF POWER BRAKE AND/OR POWER STEERING WILL INCREASE THE BRAKE PEDAL FORCE AND/OR STEERING EFFORT NECESSARY TO CONTROL THE VEHICLE. GM HAS USED SEVERAL DIFFERENT HYDRAULIC PUMPS FOR EACH MODEL YEAR. ODI WILL CONDUCT AN INVESTIGATION TO DETERMINE WHICH HYDRAULIC PUMPS ARE FAILING BY VEHICLE MODEL AND MODEL YEAR AND THE CONSEQUENCE ON VEHICLE CONTROL.
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
