Old 01-22-2004, 04:03 PM
pmartino pmartino is offline
2000 Civic No Coolant Circulation
Problems with my girlfriend's 2000 Civic, struggling for answers.
She was driving it in extreme cold, all of a sudden the heat stopped, then it overheated. She stopped, when she started it again she thought she heard a noise like marbles rolling around in a pipe from behind the radio, but she's not really sure.
Anyways the top hose is hot, bottom hose cold. Civic is backwards system I think because the thermostat is at the end of the bottom hose.
I changed the water pump (took a chance, old one looked fine though), then the rad last night. Same problem, coolant is not circulating. The hose going to the heater core is cold as well.
We think maybe something is blocking the circulation through the holes in the engine, maybe a piece of head gasket or something?
Anybody heard or seen anything like this?? 2000 Honda Civic 1.6 non-VTec, 85000 miles or so.
Paul
Old 01-27-2004, 10:17 AM
HamsterStyle HamsterStyle is offline
Send a message via AIM to HamsterStyle
have you tried changing thermostat? is ther eoil in the coolant? if not than it is not head gasket. if she is hearing gurgling in the dash it sounds like it is just low.
tommy
Original PH member since May 2000.
Old 01-27-2004, 08:53 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I would try thermostat, its easy, and relatively cheap.
05 Civic Coolant flows to overflow, doesn't come back plmnwater '01-'05 Civic 3 01-25-2011 04:40 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
Coolant circulation diagram Taylordl Caravan | Voyager 0 02-21-2007 08:07 AM
2000 Civic Si vs. 2000 Civic Ex turbo NerveAgent '96-'00 Civic 12 12-03-2004 10:51 PM
After-run coolant circulation rp2813 Passat 3 08-05-2004 03:10 PM
