Old 01-22-2004, 03:41 PM
shockley shockley is offline
Need help with blinker not working
I have a 1986 GMC 3500 1ton dually that came with a diesel motor which i have converted to a 350, anyway the blinkers work slow and when i apply my brakes the left one quits flashing and the indicater arrow on dash stays on.I tried a larger flasher and the blinker speeded up, but when brake lights came on, left stoped flashing again.Please Help!!
Old 01-22-2004, 05:39 PM
comp comp is offline
check for a short, does it do different on the left or right????
Old 01-24-2004, 11:22 AM
michelq michelq is offline
Re: Need help with blinker not working
chech for wrong bulb to left rear light and for bad ground left front
Old 01-25-2004, 09:17 AM
billy2 billy2 is offline
I had the same thing happen on an '85. It turned out to be the ground wire that attached to the frame had corroded in two. It was the one located on the driverside rear of the frame, I think it was a black wire held to the frame with a 10mm screw. Check that, it could be your problem.
need help with my 86 mustang cobra gt the fuel pump is not working any quick methods 86gtcobra50 Mustang Talk 0 07-01-2009 11:20 PM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
need help with 94 not starting momof2 Cavalier 1 07-02-2006 11:24 AM
Right rear blinker not working suthernricer General Discussion 0 10-20-2003 01:31 PM
Need help with 84 GL, Turn Signals not working! lbrowne '71-'87 Civic | CRX 7 07-07-2002 12:05 AM
