rear window problem
I am trying to troubleshoot a rear window problem on my 1990 4Runner. My rear window goes down with no problems, however whenever I try to bring it back up, either by key in the back or by switch in center console, it does not want to go back up. I have to push on the center console switch for a minute or two before it will engage. Any suggestions on what I should check and how to go about tackling this problem?
Thanks in advance. |
Rear Window
I've heard ppl talk about 4runner rear windows getting stuck when the wiper on the back gets moved down a little and trips a sensor. It doesn't allow the window to move. I dunno how much that helps, but you might mess around with it some.
Re: rear window problem
95% it is the window motor that needs replacement. You can buy the Toyota 4runner manual and do it youself , not big deal, it might take you up to a few hours. Try not to buy a new motor(way too much) or from the junkyard(will not work). My advice is to order a used or remanufactured motor with warranty on the internet. Just for setting your parameters : on partsamerica.com a new one is $119.00. "speedycarparts.com" is a good company too. Don't go to "cherryautoparts.com" - the worst customer service I have seen for 3 years in the US.
I hope that will help. Let me know how it worked out for you. |
hi you can go to the junk yard and any toyota window motor will work. if all you need is the small gear that works the mechanism for the arms on your window. secondly you may have to change the nylon berarings that run in the tracks of the window itself.
i have done over 12 of these and they work perfectly when completed. you use a sealed bearing the same size as the track. and drill out the nylon one and attatch the bearing using a hood pin. this might take some time and you need someone that can file downthe hood pin in order for it to match the hole you are putting it into. measure the length of the original pin to keep the same for thje new one. this repair wont allow the bearings to wear out and im sure the truck will long be in the junk yard by the time the repair is used up. if you want to know more just email me at [email protected] |
