Old 01-21-2004, 11:40 PM
skyllz skyllz is offline
95 RS RIMS Question
I got a 95 RS-t (hahn stage 1), I bought some 18"x7.5 Adr Spade 5 lug rims to go with it. I was told it will fit my car and all, but now my dad says they wont fit. According to the manual and whatever it goes up to 16"x6.
Do I need to do any cutting or whatever to fit these on? Will it be a problem when driving?
Thanks
Old 01-21-2004, 11:43 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: 95 RS RIMS Question
You're dad... is wrong. Sorry. You can fit 19's on an eclipse. As long as the bolt pattern is right, your 18's should fit fine. The worst thing that wil happen is you might rub your suspension a touch, depending on your offset. But you should be fine. easiest way to find out.. is to put them on! good luck
V8's are like tampons, every pussy needs one!
Old 01-22-2004, 09:10 AM
That is what I thought, he said because the width (7.5 inches) is too large for the back but I dunno, I will probably take it to a shop and see for myself.
The rims are 42 offset too.
Post your opinions.
Old 01-22-2004, 09:59 AM
I have 18x8.5 konig imagines on mine. with a 40mm offset and they fit fine. You should be more than good with 7.5 So don't worry. slap those things on a post a pic!
Old 01-22-2004, 12:07 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Good thing to do is put the fuckers on and see for your self! Like said above i have seen 19s on an eclipse
Old 01-22-2004, 12:46 PM
Yea, I will post a pic and all after I get em on. Anyway I am in (Calgary, AB) Canada and am wondering where I can find a good place for tires and how much it would run me?
Old 01-22-2004, 12:51 PM
wilson83 wilson83 is offline
I fitted an ADR Sokudo 18" with 45 offset on my Eclipse 96 RS, and it looked awesome. Don't forget to lower your car, I have Tokico's shocks and springs fitted and lowered 1.8", they look so pimping now, so much better than before it was lowered. Just a suggestion.
Old 01-22-2004, 11:26 PM
hey wilson man post some pics ! Lets see your ride with those 18s.
Please Help me answer some questions with Rims Banana_Peter Mustang Talk 2 02-21-2009 10:55 PM
Light rims question!! mellowboy Tires and Wheels 9 12-13-2001 01:34 PM
Rim Question ??? Whistler! Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 09-25-2001 10:57 AM
