Old 01-21-2004, 11:02 PM
DiGiTaLEcLiPsE's Avatar
DiGiTaLEcLiPsE DiGiTaLEcLiPsE is offline
Send a message via ICQ to DiGiTaLEcLiPsE
Another Respirator Question..
If the respirator mask says it will protect you and block out 95% of the stuff.. should I be worried about that missing 5%?
Old 01-22-2004, 03:25 PM
lotus_man's Avatar
lotus_man lotus_man is offline
If I was working in a confined environment with limmited extraction I would! Realy depends on what and where you are spraying. With my respirator I get 100% filtration even sprying heavy duty laquers in doors with just a window for ventalation.
My current work-
Old 01-23-2004, 03:40 PM
What if I was planning to use it in a 20ft high ceiling garage that can fit one car. Is that good enough to forget about the 5% ? Or should I buy another one to be on the safe side?
Old 01-23-2004, 03:58 PM
lotus_man's Avatar
You have plenty of space, the next thing to consider is where your fumes are going to go. You need to get them out of that space as best you can. You either need to get good airflow going through the garage (great for clearing fumes, but can blow dust and grit all over your fresh paint) or rig up dome kind of extraction system. The first option is cheaper, and to be honest what I do... It's all about compromise. The ideal solution is to spray in a clean room with filtered air supply and extraction system like the pros have. However that's unrealistic even for most pro modelers. I'd go with a good respirator, like you have, ventilate your spraying area as best you can and maybe think about either buying or building a spray booth if you think you need it.
My current work-
Old 01-23-2004, 06:31 PM
Well, my plans are to just do most modeling in the winter or something.. During the summer what I will do is just keep the garage door open when modeling.. Is that good?
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
Another paint question. JE123 Car Modeling 11 06-18-2002 06:20 PM
Another Tire Question MiltSA 1st Gen 95-99 4 12-20-2001 01:18 AM
Another Bilstein Question ToeJam Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 27 08-13-2001 12:56 PM
