Old 01-21-2004, 10:36 PM
CrimsonRacer's Avatar
CrimsonRacer CrimsonRacer is offline
Send a message via AIM to CrimsonRacer
Boost Leak or what?
My friend has a 96 GST and wanted me to post about this problem. He said when he reaches a certain boost level, the car wont go and feels like its running out of gas. I was wondering if any of you have a clue as to what the problem is because hes freaking out. Thanks
Old 01-21-2004, 11:18 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Boost Leak or what?
what psi is that? it can be if he has a stock t-25 he can be maxxing out the turbo b\c it max out at around 17psi and even lower i believe with stock fuel managment.
1
Shift_BOOST
97 s14
Old 01-22-2004, 12:22 PM
rysbrnr's Avatar
rysbrnr rysbrnr is offline
Depending on what mods he has the problem could be the ECU is pulling ignition timing way back if it sees too much knock. Is your friend just running a boost controller and nothing else? Does he have any fuel upgrades at all? What does he have done to it?
01 Audi S4 - "stage 2" mods 13.5@101 on snow tires & 91 oct.
01 Integra Type R - mostly stock w/JDM front conversion
94 Acura Legend - stock
92 Eagle Talon Tsi AWD -
TD05/06 20g turbo, 3" downpipe,Apex-i N1, K&N filter, ported 2g manifold, tubular o2 housing w/Tial 35mm W/G, 2.25" IC piping, Apex-i Intercooler, Blitz BOV, 650cc inj, 255;ph pump, Aeromotive AFPR, Aeroquip -6AN, Apex-i S-AFC, AVC-R, + more
Old 01-22-2004, 02:11 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: Boost Leak or what?
does he have a boost gauge? turbo2nr is right. after 5k rpm or so, boost starts to rapidly drop off because the turbo can't keep up, and he will feel a pretty noticable loss of power, where the rpm's keep going up, but the acceleration is no where near what you think it should be, sorta like loosing gas. getting a boost controller would help a bit, but only a bit.
Old 01-23-2004, 01:13 PM
kjewer1 kjewer1 is offline
AF - Advisor
If it is stumbling/stuttering (I'm assuming so because of the running out of gas comment) it is almost always an ignition related problem (plugs, plug gap, wires, etc) or a boost leak (see www.vfaq.com to make the tester, and test it either way. Everyone should do this, like, now.)
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-23-2004, 06:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I've been running my car for about a week now with what I think is a boost leak. I'm waiting for my automotive class to get into gear (haha) and take safety tests so I can use their expensive lifts and get credit for it too. Shouldn't be too hard to check for boost leaks, even though the teacher knows little about turbos.
