Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 01-21-2004, 11:22 PM
iwoopany1 iwoopany1 is offline
door panel
i have a 300E and the window on the drivers side door is broken, either not aligned or some gear is broke and i was wondering how to remove the door panel so that i can realign the window or whatever i need to do
Old 01-31-2004, 08:20 PM
pkmaven pkmaven is offline
Re: door panel
DOOR PANEL REMOVAL FOR MERCEDES-BENZ 124 BODY STYLE
1. REMOVE 2 SCREWS FROM ARMREST
2. PRY OFF SEAT CONTROL KNOBS AND RETAINING SEAT CLIP FROM POWER SEAT CONTROL ASSEMBLY
3. PRY OFF DOOR LATCH COVER-REMOVE PHILLIPS SCREW
4. REMOVE SCREWS FROM LATCH TRIM
5. PRY BACK PLASTIC TRIM @ TOP OF DOOR HANDLE & REMOVE ONE 10mm BOLT.
6. LIFT UP FIRMLY ON BOTTOM OF PANEL TO REMOVE PANEL CLIPS FROM DOOR FRAME. (CARE MUST BE TAKEN TO REPOSITION BRASS FASTENER CLIPS UNDER REAR WING WEATHER TRIM BEFORE REINSTALLING THE WEATHER TRIM STRIP. PEEL BACK THE RUBBER & REPLACE THE CLIPS. PLACE BRASS CLIPS ONTO WEATHER TRIM STRIP AND REINSTALL THE STRIP). pkmaven
Old 02-01-2004, 12:00 PM
ok thanx
i forgot to mention that this is an 83 and you said to remove the screws, but i dont see any
