Old 01-21-2004, 10:06 PM
Bline Bline is offline
Automatic power door locks
Does anybody know how to disable the automatic door lock? I want to still use the power door lock but as it is now the doors lock when you start the car. I have been locked out a couple of times.
Thanks
Old 01-22-2004, 08:36 AM
ldanley ldanley is offline
Take out fuse
Take out the ctsy fuse. Your lighter will not work but it will solve your problem. Also get a spare door key and keep it in your wallet.
Old 07-07-2004, 07:27 PM
Josh Lentz Josh Lentz is offline
hi i just got my 95 ga gt and my locks quit workin along with the cigarette lighter so i was assuming it from this post it was the ctsy fuse..so where is that located? thanks
Old 07-07-2004, 09:33 PM
i figured it out thanks any way
Old 07-13-2004, 09:38 PM
bubbleandSqueak bubbleandSqueak is offline
Send a message via AIM to bubbleandSqueak Send a message via Yahoo to bubbleandSqueak
Re: Automatic power door locks
turn key to on than hold the door lock down(like 10 seconds). you will here 4 beps and the doorlocks will not engage. your car has 4 setings and i thiank the 4th one is the one you would like if it dose not work E-mail me and i will help you some more.
Old 07-14-2004, 11:40 AM
Minitruckinbabe Minitruckinbabe is offline
Send a message via MSN to Minitruckinbabe Send a message via Yahoo to Minitruckinbabe
Curious. My cigarette lighter doesnt work but my door locks sure do once i get in gear and start going my doors lock....do they run off the same fuse and if so could it be a wire in my lighter not working
Old 07-14-2004, 11:47 AM
I Do not know if the door locks are on the same fuse or not but look in you manul it will say where and the fuse is and if you would how to stop your doors from locking.
Old 11-05-2005, 10:41 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
1994 PONTIAC GRAND AM L4 138 3 2.3L MFI SOHC QUAD - Power Door Lock Does Not Work.
Problem: The power door lock switches on the driver side and passenger side does not lock or unlock. The door locks automatically when the vehicle is running and the transmission is put in Drive. However, the door locks does not automatically unlock either when the transmission is put in park and engine turned off.
Solution: I checked the fuses for the DR UNLK 10 amps fuse and DR LK 20amps fuse. The two fuses DR UNLK and DR LK are both fine. I did not remove all fuses because some of them are pretty straight forward and not related to the power door locks. I did want to necessarily unplug all the fuses as they may have preset memory that I have to reprogram again. I went online to check for other possible solution and hints from other individuals who have the same problem like I have.
It turns out to be a blown fuse that controls the cigarette lighter is also used by the power door locks.
http://members.fortunecity.com/slade...ockProblem.pdf
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
