Old 01-21-2004, 08:39 PM
3000GT4ME 3000GT4ME is offline
Send a message via AIM to 3000GT4ME
Brake light stays on....
The last 2 or 3 weeks when i take my e-brake out the light still stays lit. Sometimes it will go off but then it will go back on after a little while.
I also have a problem with my rear wiper blade, i think my switch is messed up cause i can turn it on fine but then it takes a while to get it to stop. I have to hit the button like 50 times to get it to turn off.
And yes my last question, i am getting new brake pads... is there really any that are better than the others??? Anyone want to point me in any certain direction.
3k isnt just a car...... it's a life!!!!
Old 01-22-2004, 12:37 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
by your ebrake light I assume you mean the general brake light, and thats because your brake fluid is low. However you wont have to top it off because when you get new pads it will push more fluid back into the resivoir.
Old 01-22-2004, 07:22 AM
BB1970's Avatar
BB1970 BB1970 is offline
Brake Pads
GOT EBC REDSTUFF PADS IN MY GTO AND THEY ARE GREAT. WARNING!!!!! THEY ARE EXPENSIVE THO, (£85 A SET) BUT DONT FADE OUT AS QUICK AND ARE MUCH SOFTER AND KINDER TO YOUR DISCS.
CAN SUPPLY TO YOU IF YOU .WANT ME TO.
BRIAN
Old 01-22-2004, 08:32 AM
Re: Brake light stays on....
By my brake light i mean the red light to the left of the speedometer that appears when you pull your e-brake. Will me replacing my pads fix this problem or were we thinking of two different things?
How much are these brake pads to be shipped and everything in dollars.
Anyone know anything about the windshield washer problem?
Old 01-22-2004, 08:33 AM
Anyone know anything about the windshield wiper problem?
Old 01-22-2004, 10:31 AM
BB1970's Avatar
Brake Pads
you are looking around $150 for the brake pads and around $40 shipping.
yes that will put the light out, the reason it is on is because your caliper pistons are pushed further out due to the pads being worn down.
as regards to your rear windshield it could be down to the switch itself or the delay relay (for intermittent wipe.) does it do it on both positions of the switch?
Old 01-22-2004, 10:35 AM
BB1970's Avatar
i would also recommend a complete brake fluid change if it looks dirty,
my gto brakes feel completely different since i changed mine.
brian
Old 01-22-2004, 11:10 AM
It is my rear windshield wiper, which is on a button switch to the right of the steering wheel. It just takes forever to turn it off, so it isn't a intermittent wiper, i think it is the switch... i dont know what i could do about that besides get a new switch, which would probably cost a lot. It really sucks to not use that wiper.
I do think that the brake light is cause by my brake fluid... i will check that after work.
Old 01-23-2004, 02:14 PM
Igovert500's Avatar
blue + red light magnet
brake light and pads
I had the same thing with the brake light, I was low on fluid. I also changed my front pads and upgraded to the Stillen MetalMatrix pads. These are good pads, I think I got them from 3sxperformance.com for 55 bucks (110) if replacing the rear pads as well. My only complaint is that because of the metal, you have to heat them up a bit before they reach ideal stopping power. I read somewhere that the MetalMatrix pads were still pretty good in cold conditions. But honestly there have been a few times where I would have liked more stopping power. In all honesty though, our stock brakes are quite good and do not really need to be upgraded unless you plan to be flying at speeds over 150mph often. I have heard many other people say the redstuff pads are quite good. So I would go with something like that. Check around on the internet at various sites and you may be able to save some money.
Old 08-19-2004, 12:06 PM
Briz0r Briz0r is offline
Send a message via AIM to Briz0r
uhh so when u changed the fluid and pads the light went away? i have the same brake light on problem and wondering if that worked for you.
Old 08-19-2004, 01:41 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Hold up, i think you guys are confused.
The brake light that you are talking about is the light between the speedometer and the tachometer. This light comes on when the e-brake is activated. The e-brake is DIFFERENT from the rear disc brakes. The e-brake is a drum brake inside the rear hubs (see pic below from the manual), and the rear disc brakes (which operate along with the front disc brakes when you push the break pedal) are on the discs outside of the rear hub assembly.
You can adjust the e-brake 2 ways. You can either take apart the rear hub assembly and adjust the spring there (hard way) OR you can remove the center console storage box (behind the shifter, cig lighter, ash tray directly between the two front seats) and adjust the e-brake cable there. Simply, with a wrench, turn the bolt to the left or right (i forget which way) to tighten or loosen the e-brake.
As to your question regarding the e-brake light staying on...perhaps your e-brake is not fully disengaged when you take it off. This would occur if your e-brake cable is adjusted to a very tight setting. By simply loosening the cable via instructions above, this should solve the problem.
As to your rear wiper problem, it sounds like your switch. If the switch is stuck, you might remove it and inspect it to see if it operates smoothly and look for any objects/pieces hindering movement. But you might just get a new switch. I've seen them on e-bay for about 10 bucks.
Good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-19-2004, 02:58 PM
thanks for to good information
Old 08-19-2004, 03:18 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Yea I was having that problem too, till I went through a big hole in the road. The problem started when my mom decided to ram my car because she wanted to get to a salon on time and it was blocking her in the driveway... I think it only needs to be tightened but if it ends up being more she'll pay . She told me to move it but I couldent because I had a box with a new tower computer and monitor in it in my arms!
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-19-2004, 05:19 PM
so i removed the center console and loosend the e-brake and the light still stays on any idea on what else it could be?
Old 08-19-2004, 08:14 PM
Linebckr49's Avatar
you might check the fuse box, underneath the dash on the driver's side, just next to the hood latch.
93 3000GT base
