| Let's get Technical! Discussion for hardcore in-depth motor heads! |
Vtec Not Working, Need Help Please!!!!
ok here is the situation. i did a motor swap. i have a b16a block with a gsr head. everything is wired up and the car runs. the only thing wrong with the car is that i have a coupl eof engine codes. the codes are i think 1, 13 and 14. i know that 13 is that air idle valve(im going to change the throttle body to fix that) but 14 is barometric pressure code. i have no idea what that is or how to fix it. i know tha barometric pressure has to do with the altitude where i live and stuff like that. but what would cause me to get that code and how can i fix it? im not getting any other codes. i may be getting a code of 3 but not sure. if any1 can help i would appreciate. sorry about the lenght.....
well, im guessing hondas are MAP based. the manifold absolute pressure sensor(P), combined with a temperature sensor(T (in kelvin)), tell the ecu how many molecules(n) are going into your engine with the formula PV=nRT (chemistry stuff).
so check around your intake manifold for a sensor. thats the one you want. or maybe just tripple check your wiring for that sensor. you could have mixed something up. |
Re: Vtec Not Working, Need Help Please!!!!
Thanks. Ill Check It Out. I Also Think The Reason My Vtec Wont Work Is Bc Of My Oil Pressure Switch. So Im Gonna Replace That And See If It Works. Thanks!
check your oil too and your vaccum hoses
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler |
