Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 01-21-2004, 07:22 PM
Veil_Side_ Veil_Side_ is offline
Question EGR Valve location and cleaning
Hey cats.
Okay, first things first. I got the dreaded Check Engine Light. Took it to the local Autozone and got it diagnosed and yup. The dreaded EGR Malfunction code followed by an even more dreadful price for the replacement part. So yeah, I've seen wedding rings that cost less. Anyways. I need to know some things which I have carefully numbered for you convenience and any help will be valued. Unless I get a reply like 'smoke weed everyday'.
'98 1.5L Mazda Protoge
1. Where is the EGR located on this car?
2. How do I remove it?
3. How do I clean it?
4. What products did you use?
Hell, if you just answer number one, I'll be happy.
Thanks again.
'92 240SX
Wish List:
Lancair 360
Old 02-27-2004, 06:26 PM
nutome02 nutome02 is offline
did you figure that out yet because I'm changing mine tomorow and I havent even looked for it yet
Old 04-23-2004, 04:15 PM
mitsuorder mitsuorder is offline
Re: EGR Valve location and cleaning
bump, I'm about to do this on a 1999 1.6L Protege and would appreciate some insight
awaiting...
Old 11-15-2005, 08:33 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
a friend is also having this problem and I need to find it too.
Old 11-16-2005, 12:08 AM
matmandude007 matmandude007 is offline
Its on the back of the engine behind the throttle body.
Old 11-16-2005, 07:30 AM
mazdatech177 mazdatech177 is offline
dude, just take the valve back, that aint the problem. remove the throttle body, youll see a nasty carbon buildup about 2-3 inches in. clean this mess out. then clean the vacuum port on the outside of the intake right next to the egr valve itself. the buildup is causing a false egr flow reading. use some carb cleaner and make sure you can blow through the ports with compressed air. theres should be free flow from the port you cleaned inside the intake to the external port next to the egr valve.
Old 11-26-2005, 03:06 PM
Audio Guy
I took a pic ..... tell me which one is the EGR valve. I am guessing it's the thing just to the right of the exhaust port with a screw on each corner.
http://img259.imageshack.us/img259/3225/img00014nx.jpg
