Go Back   Automotive Forums Car Chat > Opel/Vauxhall > General Discussion
Old 01-21-2004, 05:48 PM
Katie3873 Katie3873 is offline
Question Holden Question
Hello all,
My car is 96Holden Barina. It recently got a problem. The reverse lamp would not light on when I switch into reverse gear. I've checked the electrical circuit. The bulb is definitely okay and it seems the fuse (#18) is okay too. Anyone got this experience and would tell me how to get it fixed? Thanks very much for your advice. :0)
Old 01-22-2004, 07:23 AM
stagger lee stagger lee is offline
Hey Katie3873,
Check your reverse lamp switch on the shifter mechanism,although I've never worked on a Barina this is a problem that I've encountered on other makes.Look for loose or adrift wiring,failing that it could be a simple adjustment issue.
Old 01-23-2004, 12:19 AM
Re: Holden Question
Thanks stagger lee. It seems not easy to find the reverse lamp switch. Does the job cost a lot of $$$ if I ask a dealer to get it done?
Old 01-23-2004, 05:51 AM
I wouldn't imagine it would cost to much,maybe an hours labour plus parts if required.Over here you'd be looking at around the $80 to $100aus from a dealership probably less if you found a sympathetic and trustworthy independant workshop.
Stick with a dealership though if your unsure of the mechanical workshops in your area.
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
Holden question... onetoolfan COMPLETELY off-topic 27 02-13-2005 11:23 PM
Holden Question TheScientist General Discussion 7 12-21-2003 10:52 PM
