Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-21-2004, 02:47 PM
txmalibu00 txmalibu00 is offline
Unhappy thermostat??????
hey everyone.... i need help... i have a 2000 malibu....that keeps on over-heating on me in short distances...they tell me it may be my thermostat...only thing is i dont know where it is located... so if anyone who owns a malibu can tell me where i will be able to locate the thermostat... it would be great... thanks
Old 01-21-2004, 08:31 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: thermostat??????
This doesn't belong in this section...
www.cloudcity.deviantart.com
Old 01-21-2004, 08:45 PM
Rich's Avatar
Rich Rich is offline
Never Fear, Rich is here!
Send a message via MSN to Rich
It sounds like it could be the thermostat ......stuck closed.
I haven't personally worked on a Malibu, but as a general rule of thumb you follow your top rad hose from the rad to the block, and you should see the housing.
My Wheels
15' Kia Soul SX 2.0L
13' GMC 1500 P/U 5.3L
Old 01-21-2004, 08:48 PM
SUBSAILOR SUBSAILOR is offline
Banned
its on the drivers side under the air intake
Old 11-08-2004, 06:11 PM
shakerr shakerr is offline
I have a 93 Escort also..and tried to find the rad thermostat....no luck,,
is there a fair sized housing that has to come off at the end of the top rad hose?
thanks in advance...
Old 11-08-2004, 06:56 PM
bearcatdon bearcatdon is offline
As Rich said follow the upper rad hose and you'll find it next to the exhaust manifold. Have fun. It's not easily accessible. I changed mine when I had access to it while doing my intake gasket.
Old 11-12-2004, 06:39 PM
fastk fastk is offline
Yeah, my Haynes manuals says it is under air intake if it's a V6 model.(Air filter housing hose)
First, you need to drain coolant (not all, about half and if it's clean then use it again)
Second, remove air intake housing.
Thrid, disconnect the hose and repleace the thermostat.
Good luck! buy manual!!
Old 01-10-2005, 02:36 AM
krushmoto krushmoto is offline
MAKE SURE YOU BLEED THE SYSTEM AFTER REPLACING THE THERMOSTAT!!!! I didn't and my car overheated from air in the system.
2002 3.1 thermostat removal DigduG1975 Grand Prix 1 05-29-2010 08:47 PM
Suddenly no heat - thermostat? grandmarq Grand Marquis 0 02-26-2009 06:38 PM
Upgrade Thermostat What is the Stock Thermostat? Stealth-Twinturbo 3000GT/Stealth 0 06-19-2005 11:08 PM
high temp. thermostat vs. low temp. thermostat amyindallas Cutlass Series 1 06-07-2004 10:31 PM
