Old 01-21-2004, 12:37 PM
4speed 4speed is offline
Transmission problem
I've got a 96 4cyl 5spd with 104,000 mi. About a week ago it started jumping out of 4th gear while driving. At about 70,000 mi. I replaced the clutch and input bearing / seal. Is there a problem with these transmissions? Has anyone bought a trans. from any of the importers? I'm not sure if it's worth rebuilding the trans. when you can get one with very low miles for a few hundred dollars.
Old 01-29-2004, 04:37 PM
geozukigti geozukigti is offline
Metro trannies are small, therefore have small, weak synchro's. You can rebuild it, just put all new synchro's in, and use 75w90 gear oil. Also check www.car-part.com for junkyard transmissions for pertty cheap.
Old 02-26-2004, 12:16 PM
Re: Transmission problem
Is there a rebuild kit or buy all piece parts? Is the best place a GM dealer? Have you rebuilt one?
Old 02-26-2004, 12:20 PM
Also, is the 96 trans unique or will other years fit? Thanks for the quick reply.
Old 04-08-2004, 11:41 PM
lucyseabug lucyseabug is offline
I'm sure you guys have already hashed out alot of stuff already and I'm very late on a useful reply, but...
I rebuilt my 5 speed for about $150.00. I bought a metro rebuild kit from a trans supply house. Just say you are a mechanic and work for so and so and pay cash-customer will call. I replaced my clutch also and that raised it to $260.oo (clutch kit was $110.oo that I bought retail). I just looked at one of those Haynes manuals and pulled the gears and synchros off the shafts and did not replaced the needle bearing cages. It seems as though the oil pump laps up the oil into the 2 main shafts. The shafts were clogged with RTV and plastic crap and would not let oil up into the input and drive shafts. Be prepared to use a NICE clamshell puller because a press is useless. I'm a gearhead so I thought it was easy but for the mechanically declined it could be a complete brain drain. Sell me your old hammered metro manual trannys. I'd like to get into this.
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
