Old 01-21-2004, 09:50 AM
Perplexed1 Perplexed1 is offline
New 2003 Running Hot
I have just purchased a 2003 Suburban (LT, 350, 4x4, auto). The temp gauge shows almost 210 around town and on highway. I also have a 1998 Suburban (LT, 350, 4x4, auto) that has always run at about 160. Is the new one (600 miles) running hot?
Old 01-21-2004, 12:06 PM
Bremln Bremln is offline
Re: New 2003 Running Hot
Sounds like the thermostat in the 2003 might be bad, although I don't know why it would. There are a number of other things it could be too. Have you checked the coolant level in the radiator?
Old 01-21-2004, 11:46 PM
jfmctlaw jfmctlaw is offline
You need to find out what temp thermostat you're supposed to have. A local autoparts dealer or your local GM parts guy should be able to tell you. Is your fan belt properly tensioned? Any leaks on the ground under the engine area when you park? Are you losing coolant but don't know where it's going? Does excessive water drip from your tailpipe?
Old 01-22-2004, 09:36 AM
The coolant level is fine, there are nop leaks, the belt seems tight, no excessive water from the tailpipe.
1999 cherokee 4.0 running hot....sorta wkumale Cherokee 11 09-15-2010 09:05 AM
Isuzu Rodeo Runs HOt WNathan67 Rodeo | Passport | MU 1 07-03-2010 08:29 PM
New heads, still runs hot foreman72 Lumina 6 06-09-2007 01:30 AM
new 318 engine is running hot dodge65 Ram Pickup | Ram SRT10 7 12-14-2005 05:08 PM
How hot does your NEW impala run victimizati0n Impala | Impala SS 9 06-28-2005 11:57 AM
