Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-20-2004, 09:07 PM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
A Contraversial Issue!
Ok here it is...........What is a better set up a turbo car to its fullest potential, a superchaged car to its full potential, or a N/A car to its full potential??? Which one do u think is the strongest?
Old 01-20-2004, 09:19 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: A Contraversial Issue!
If you are talking about the same motor for a base to start from then the turbo motor will be the strongest, but the N/A motor will probably last longer. If you are talking about a honda motor lets say a B18C1 then the turbo being in first place and the N/A being second and the SC being last. That is if you are talking about a roots style SC. My
Old 01-20-2004, 10:06 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
AGGG!!! TOO MANY VARIABLES!!! hasnt this discussion been done a dozen times over?
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 01-23-2004, 11:12 AM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
The Answer is Yes...
DoubleTap
Old 01-23-2004, 01:12 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Turbo will be strongest if built right. Good turbo, 30psi...
Old 01-23-2004, 08:36 PM
whtteg's Avatar
Re: Re: A Contraversial Issue!
Ok man 30psi is in no way streetable! Never will be either, please give some good constructive advice
Old 01-23-2004, 08:44 PM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Ok NA will last the longest. Least heat to degenerate seals and such, and less internal temps to deal with.
Turbocharged will give you the most power, but it will run very hot. Seals will not last as long as an NA. Also you will have a harder time tuning that you would on an NA car.
Supercharger offeres the best streetability. You can get reasonable power from it and be happy. It causes less wear on the engine because it is not as hot as a turbo. But it will cause your crankshaft end bearing to fail prematurly, possibly causing crankshaft endplay. (this is caused by the stress the SC belt puts on the crank belt)
So if you are doing up a Honda motor for street use go with NA. If you are set on getting forced induction go with a SC. Dont get a turbo, to many things to go wrong on a car that was not designed for a turbo.
Good luck
Old 01-25-2004, 07:32 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
30psi...do you have any idea how much power you would be making with 30psi on a B18C1? that would be triple plus some baseline power..not to mention your baseline power would be higher than just the 170(?) that a B18C1 makes because of the thousands of dollars worth of upgrades you'd need to make in order for that engine to handle such high power gains..but anyway...yes...Turbo = your best bet if you want a racecar...sure NA lasts longer...but who really needs an engine to last long if it's not fast? and I'm not even commenting on S/Cs...what a waste.
Old 01-25-2004, 09:05 PM
joebowlr21 joebowlr21 is offline
Send a message via AIM to joebowlr21
come on fellas you can't knock s/c's.Are you gonna tell me you are not impressed with vortech's s/c kit for the civic Si an gsr???
271 street legal and smoggable ponies to play with.Tell me of a turbo kit you can bolt on an make 100+hp without further tuning including raising the boost and keep the car street legal.
S/c's are great for reliability if done right.
Now i'm not saying that it is better then turboing because i love the sound of my t25 spoolin and the sweet sound of my blitz SSBOV, but you can't completely knock s/c's.
Old 01-28-2004, 05:55 PM
dampachi's Avatar
Banned
Yeah, you got a point...S/Cs do serve a purpose...if you wanna bolt on some power to a car and that be the end of it...sure...but you know..when it comes to making a 400hp+ engine you need a turbo.
Old 01-28-2004, 06:26 PM
boosted331 boosted331 is offline
I'm not impressed with the vortechs at all. They're making 270 smog legal horsepower. Guess what, you can make 270 TO THE WHEELS smog legal with a bolt on turbo kit. With a turbo kit you actually get more low end torque, instead of having boost ramp up with RPM's like on a vorturd. Not to mention not having to deal with belt slip, you don't need to change pullies to adjust boost with a turbo, and a turbo doesn't put all that strain on your #1 main bearing like a blower does.
Old 02-01-2004, 12:03 AM
first off all i'm talking about vortech's centrifigul S/c kit.But i'm pretty sure you knew that since you were talking about belt slippage and blowers an what not.
So your telling me that you have a turbo kit that will slap on to a civic Si and with no further mods and make a dyno proven 271Hp to the wheels.........i'm sorry i call BS!
Plus with wut ur saying you can take it to any smog station in CA and it will pass no problem...... serious BS there.
Please show me to this magical kit that i can buy with prove from dyno runs about this 271 TO THE WHEELS!!!
I'm not knocking turbo'ing at all, i'm just saying that with a mass produced s/c kit u can make a 100% power gain.Most if not all turbo kits only show a 60% gain in HP.So bring me some facts oh these "turbo kits that make 271HP @ the wheel"
please.....i dare ya.....
Old 02-02-2004, 03:16 PM
andera andera is offline
Send a message via AIM to andera Send a message via MSN to andera
Piece together a turbo "kit" for $1500... and Uberdata with a Dyno to tune your car and you can easily make 12PSI (which is around 260HP i think... sorta depends).... then if you want mad HP you rebuild the engine... run around 20PSI (lots and lots and lots and lots of HP) for a couple of grand more.... Granted at that point you'll need a new clutch and LSD, but for not a whole lot more you've got a whole shitload more than you'd get with a S/C. Just seems stupid to buy any kit... and especially stupid to buy a S/C kit... research everything and go turbo
Old 02-02-2004, 05:05 PM
1995 Ls shortblock
1989 Ls head
Completely stock internals
Pump gas 93 octane
GE blockguard
Greddy 660cc injectors
Hondata S100
2.5" downpipe
3" thermal exhaust
Precision SC61
This run was done at 14 psi. We kept it real conservative because this is a daily driven vehicle. We could have pushed it more...but the owner of the car was very happy with the results at 14 psi so we stopped there.
14 pounds of boost on pump gas on an LS motor. That would EASILY pass smog, and that would make more power with less boost on a B16. Centrifugal superchargers are inferior power adders on high revving small displacement motors.
Old 02-04-2004, 08:27 AM
m0nee m0nee is offline
Interesting SHIT!!
