Old 01-20-2004, 08:18 PM
Aaron91ef9 Aaron91ef9 is offline
Send a message via AIM to Aaron91ef9
Exclamation B16a swap problem
I just swapped a b16a1 into my 91 hatch si and everything is running good except when my engine gets to operating temp. the idle jumps from about 1300-800 rpms back and forth until I shut off my engine. Im not getting any ECU codes. I was told that it I might need to adjust my idle adj. screw, but im not sure if that will help. Please help!!
thanks everyone!
Old 01-20-2004, 08:32 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: B16a swap problem
Check your idle screw first, if that doesnt fix it, unplug your EACV valve, and see if it stops. If it stops, your valve either needs to be replaced, or cleaned.
Old 01-21-2004, 06:18 AM
SiZ's Avatar
SiZ SiZ is offline
Its a pretty common problem on 1st gen B16s. The idle is just constanty going up and down. Mine did this for months. I've had it happen to me twice and both times it was the fast idle control valve.. Located directly under the TB.
"The nympho of info, I'm fuckin' what ya heard"
Old 01-21-2004, 02:54 PM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
screw all that and just go get it fixed proffesionaly not by yuorself your gonna have a lot of damage meesing wit that
Old 01-21-2004, 04:11 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: Re: B16a swap problem
same thing happens with my b18a, i wonder if its just 0bd0 engines?
As American As A Burrito!
USDM 4 life!
Old 01-21-2004, 05:34 PM
kris's Avatar
Re: Re: Re: B16a swap problem
Its all honda motors. We had a 98 integra b20/vtec setup that did the same thing. His eacv was bad.
Old 01-21-2004, 07:39 PM
SiZ's Avatar
SiZ SiZ is offline
Yep, the FITV on the B18A is the exact same one as on the 1st gen B16s also. I think these valves are peices of shit.
But even a lot of the newer OBD equipped B series motors have simliar idle problems, but they don't have the fast idle valve, they have other problems like Kris mentioned.
Old 01-22-2004, 07:56 AM
SiZ's Avatar
SiZ SiZ is offline
Here's a good link for you!
http://www.honda-tech.com/zeropost?cmd=reply&id=7606123
Old 01-22-2004, 08:59 AM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
i have sumthing similar to that problem but its oppisite when i first start my engine it will jump right to 2000 RPMs then it will jump down to around 100 RMPs when i get warm then it will start to jump from like 500 to 1200 RPMs its really pissing me off anyone have an idea the only code the ECU is throwing is the knock sensor but i kno i need to but a new one.....Thanks
