RB26DETT into a 910/Bluebird
Want to swap a rb26dett with rb25dett RWD gearbox into a 910. How difficult will this swap be! I foresee firewall modifications! Anything else to be aware of? HELP!!!!!!!!
Re: RB26DETT into a 910/Bluebird
Everything.
The whole engine weighs like 3 times as much... Please be realistic, a CA18DET, SR20DET or even a FJ20DET would be heaps of power in such a light car... |
a rb26 is only 1.5 times the weight of the ca18
It can be made to fit. you will need some big front struts and recess the firewall around the back of the motor and enlarge the tunnel |
SR20DET vs RB26DETT....hmmmm....I don't think so....already have SR20DET....want to feel power of the twin turbo....I saw a RB26 drop in a KE70 Toyota corolla, pretty simple except for firewall and shifter outlet modifications...wild ride!!!
go with RB26DETT get some new turbos and you have a dang fast car
Doug HuntDoug Hunt |
is the 910 like a 71 or around there datsun 510 my dad build one with a engine block and transmission from a 85 datsun truck. He put bigger pistons port and polish and it ran 13 sec in thrid gear. you will have a fast car
I have seen lots of blue burds with CA18DET and SR20DET transplants but none with a RB26dETT that is real power. It will need alot of work and time but the end product will be worth it. Just a thought will a VG30DETT fit better its not as long but wider. Just a thought.
hey yea i just stuck an Rb25det in my bluebird and fitted easy if u get a series 3 crossmember all u have to do is move the mounting point forward and cut off those little mounts that come of the body for the gear box its as simple as that
I have a 510 and would like to swap in an RB25 does anyone have any info on reinforcing?
