Old 01-20-2004, 07:50 PM
95fbird 95fbird is offline
Send a message via AIM to 95fbird
engine swap... what else do i need?
i have a 95 firebird with the stock 3.4 v6... i also have a remanufactured 5.7 lt1... now i need to know whether or not this will fit right in... or am i going to need to do some extra spending?
Old 01-20-2004, 08:15 PM
Marc04's Avatar
Marc04 Marc04 is offline
Re: engine swap... what else do i need?
i think the biggest thing you might need is a transmission, because to my knowledge, the stock one will not bolt right up to the 5.7. i could be wrong, this is just what i hear
Old 01-20-2004, 08:45 PM
84and85bird's Avatar
84and85bird 84and85bird is offline
I agree with Marc04, you are more than likely your going to need to get a different transmission. Odds are that your going to have to swap the computer and wiring harness too. I was talking to a guy in one of my classes the other day who payed a shop to do almost the same swap on his 95 Camaro. He said that the shop didn't to a very good job with the swap and right now he has Camaro that can't drive anywhere. Not saying that it can't or shouldn't be done, but make sure that you know what you are getting yourself into first.
By the way, if you do decide to go ahead with the swap, don't just 'get rid' of your 3.4 engine. You might be able to get a little bit of money for it by selling it to someone who has an 82' to 92' Firebird or Camaro with a 2.8 or 3.1 V6. The 3.4 can be used as a replacement for the 2.8's and 3.1's with a few slight modifications.
1985 Firebird - 2.8 liter V6
1984 Firebird - 2.8 liter V6
Old 01-21-2004, 03:17 PM
yea i kno its going to be some hard work... but i'm up for the challenge, and i have another car for transportation so i'm taking my time to do it right... now i could track down a transmission no problem, but do you know where i could get the computer for it?
Old 01-21-2004, 06:57 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Well you will no doubt have to change the computer and wiring harness..i guarantee that much and I am gonna chech for sure on the tranmission...and also..whatever tranny you get, auto. or Manual, you have to make sure that the computer is set up for that tranny, you cannot interchange them.
Just for the Stroke of it...
Old 01-22-2004, 04:56 PM
koeb$ koeb$ is offline
Send a message via AIM to koeb$
u r going to need a rear, tranny, starter, batterry, probably a bigger radiator, and maybe a stiffer suspension, and alternator
Old 01-22-2004, 05:12 PM
Re: Re: engine swap... what else do i need?
his battery prolly doesnt have enough juice, mine had to b changed when i went from a 305 to a 350
Old 01-22-2004, 09:41 PM
Would a different rear really be necessary? If I recall correctly the the rear ends and the drive shafts are the same size. Yes, the V6 rear end may be a little weaker, but assuming you don't totally abuse it should hold up. I'd think that the tires would loose traction before the gears would break. (assuming you don't have slicks)
Old 01-23-2004, 03:10 PM
Marc04's Avatar
I don't really see why he would need a battery
Old 01-24-2004, 01:11 PM
if the battery is older which im assuming it is it will not be big enough, and he is goin from a 6 to a 8 so he is looking at a lot more power to b produced. i went from the 305 to a 350 and my battery was not sufficent...i mention a few minor thing, but they were things i diddnt take into account when switching my motor
84 TA- 350 bored
dynomaax shorty headers
custom 3" exhaust
electric exhaust cut out
holley 600 cfm carb
340+HP
cam?
97 jetta
white 15" bbs wheels
2 JL 12W3's and 2 JL 500/1 amps (for sale)
Old 01-27-2004, 11:34 PM
Makenzie71 Makenzie71 is offline
Send a message via Yahoo to Makenzie71
To swap you'll most likely need:
350 longblock plus propper mounts...count on none of your factory accessories being able to bolt up.
ECU and complete uncut wiring harness. If you have a 5spd then any ECU made for your engine will work. If you have an auto you need to have an auto ECU...it should also match the year of your body. Also count on possably having to change the body harness in order to get the ECU to work power your various interior goodies. You'll prolly also have to swap the instrument cluster and definitely the fuel pump.
The transmission will need to me changed...as I'm fairly certain they don't bolt up...considering the variences in parts numbers between the two. The auto MIGHT bolt up...couldn't find anything definite on it. If you go with an auto finding one out of the same year model would be advisable.
The V6's rear is found on a number of cars...including various toyotas...it's good for typical normal driving...but if you intend to start pushing for lots of power or drive hard regularly an LS1's rearend isn't that expensive or hard to find.
You should find a new driveshaft reguardless...but it should work fine.
That's all that comes to mind right now.
