Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-20-2004, 06:04 PM
lordvektra's Avatar
lordvektra lordvektra is offline
Integra sway bar question
Im tired of understeer and I am really wanting to start auto-x soon. I have a 00 Integra GS-R. From what I understand it has a 24" front and 14" rear sway. Im looking at the comptech sway giving me a 22" rear and it would be up to par with the type-r as far as the sway bars go. I also see mugen makes a 24" this may be overkill but correct me if I’m wrong. my biggest question is should I stick with the 24" front or go higher or lower? I’m looking for neutral handling or maybe a little oversteer.
Thanks.
Old 01-20-2004, 10:55 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Integra sway bar question
Thanks.
I'd say remove your front swaybar completely first. If that doesn't reduce understeer as much as you'd like, then upgrade your 14mm GSR bar to the 22mm Type-R rear bar. I have a '00 Civic coupe and I run a 22mm Integra Type-R rear swaybar on my car. I don't have a front swaybar either.
Try what I suggested, and then post back your comments/results.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-20-2004, 11:13 PM
lordvektra's Avatar
would removing the front put my body roll over the top? right now im running on stock springs and struts and its not great now.
Old 01-23-2004, 02:57 PM
Cali Guy
Re: Re: Integra sway bar question
Nah it shouldn't. If you get a larger rear that will stiffen up overall anyways, though not as much as having one of each. Go with what I said in my first reply, and if it's a bit muc for you I'd highly suggest getting a front tower strut brace.
hessemer69 on AIM
