Old 01-20-2004, 04:04 PM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
Post How Do I Paint My Interior Of My Car?
HOW DO U PAINT THE INTERIOR OF YOUR CAR? WHAT DO I NEED TO GET OR BUY? EMAIL ME AT [email protected] THANKU
Old 01-20-2004, 08:26 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
soap
water
sponge
papertowel
krylon fusioin (from walmart but can be different kind)
clear coat
open space
remove what u want to paint clean it good and dry it, spray it, check it, fix what dosen't look good, let dry, clear coat, re install
u probably should have done a seard as this has been asked many times
91 Civic CX - Sold
94 Accord EX - Sold
94 Integra LS - Cleaning it up
Old 01-20-2004, 09:22 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Re: How Do I Paint My Interior Of My Car?
awh, newbies, go to
http://www.automotiveforums.com/vbul...ad.php?t=16804
and scroll to INTERIOR.
Ya, It's Turboed.
Old 01-20-2004, 11:23 PM
tibby01 tibby01 is offline
first off, no one is going to email you. i HATE when people ask that.
i just painted bits of my interior recently, and i must say i was very impressed with my finished product. heres what i did.
scrub peices with comet, rinse, and let FULLY dr.
sand with 320 grit dry sandpaper, and then wipe ALL dust off(or rinse and let dry)
thin coats of primer(doesnt realy matter which color, as long as you put a lot of coats of color on) with light 400 grit sanding in between. about 3 coats total.
primer sealer with light 400 grit sanding between coats. 2 coats total
THIN coats of color with wetsanding 1000grit in between coats. as many coats until desired color is obtained.
thin coat of clear top coat, followed by heavier caots until desired shine is obtained.
i got all my stuff from walmart. it is all dupli-color. the sand paper is "wet-or-dry" and has a dark grey color to it...it should be near the paint. combine my instructions with the intsructions on the cans, and you should be good to go. if i think about it, ill post a picture of my dash.
Old 01-21-2004, 12:36 PM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
is the clear coat needed?
I am painting my interior black with krylon fusion
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 01-21-2004, 03:17 PM
Bilson8tor's Avatar
Re: Re: How Do I Paint My Interior Of My Car?
its isnt neccesary espescially if what ur painting isnt going to be touched often, like if your painting the vent coverings etc., but the clear coat will give it shine, and it will protect the paint from flaking and stuff, plus the more layers of clear coat u use the shineier and more glossy it will appear
91 Civic CX - Sold
94 Accord EX - Sold
Old 01-21-2004, 04:03 PM
yea so for protective issues though you would need it...damn that sucks...MORE paint has to be bought
Old 01-22-2004, 12:29 AM
clear is not expensive at all. go to walmart, and get "clear top coat" duplicolor from the automotive center. should be about 4 bux. and you dont need that much. however, it is a pain going to walmart...i hate that store; it seems like every single customer in the whole place is just trying to keep me there.
Old 01-22-2004, 01:54 PM
CRX-Crooks's Avatar
dam all that just to paint and it smells what about interior paint?
Old 01-22-2004, 03:17 PM
Bilson8tor's Avatar
just use some kind of plastic or vinyl paint
91 Civic CX - Sold
94 Accord EX - Sold
Old 01-22-2004, 03:24 PM
the smell fasdes in a couple days. just use regular paint from walmart. maybe even get some bulldog adhesion promoter, which helps the paint stick to plastic better. vinyl paint is not needed.
Old 01-22-2004, 03:41 PM
Well supposedly with Fusion it will go on vinyl and plastics "No sanding No Primer" But I sanded anyway and I painted my door panels and stuff and I wasn't in any hurry to get them back in (I'm 15...no license yet) and so when I finally did (it had been about 1 wk) I didn't even smell the paint. When it comes to these interior pieces patience is applied TO EVERY SINGLE STEP in my book. Although this fatmat I'm installing smells like ass and there's nothing you can do except roll the windows down
