Old 01-20-2004, 02:20 PM
3.8style 3.8style is offline
Question i'm new and i have questions
i have this 88 lesabre custom and i want to start driving it, but it needs work. and since it needs work anyway i want to customize it a little. my idea is to make this car a sleeper but first i want to replace the brakes (i want great stopping power). the problem is i don't know much about the process. somebody please help!
Old 01-20-2004, 02:24 PM
97CamaroSS 97CamaroSS is offline
Send a message via AIM to 97CamaroSS
Re: i'm new and i have questions
First, stopping power doesn't all come from the brakes. you have to have a great wide tire to slow down first. then you can worry about drilled and slotted rotors. what do you want to know about the process? like how to?
Old 01-20-2004, 02:41 PM
Re: Re: i'm new and i have questions
yes i need to know how to do it. from beginning (tires, i guess) to end.
Old 01-20-2004, 03:09 PM
Do you have your reading glasses on?
ok. a buick is a relativley standard GM car. you should know how to remove the tires and have new ones mounted. that's easy.
raise the front of the vehicle and place it securley on jackstands *important* you must place it on jackstands, not just a jack. i would invest in a decent pair for about 30 bucks. remove the tires. do this next part when you have a few hours and the new kit to be installed.
ok, to remove the front calipers.
1) remove the brake fluid reservoir cover
2) take a screwdriver and push the piston on the caliper inwards to relive pressure on the rotor.
3) use an allan wrench to remove the two caliper mounting bolts.
4) disconnect the brake line from the caliper and pull it off.
5) remove the wheel bearing dust cap.
6) starighten the ends of the cotter pin in the castle nut and take it out.
7) remove the spindle/castle nut and the washer.
8) pull on the hub to dislodge it, and remove the outer wheel bearing.
9) lift the hub assembly off.
10) now install your new shtuff, after wiping the spindle down and recoating it with grease. have fun.
