Old 01-20-2004, 11:13 AM
viperlude69 viperlude69 is offline
Civic Hatch B16 swap? Hard or not?
Im about ready to buy a 89 civic si and want to know the requied things for the b16 swap...do you need new axels, engine mounts, ecu? or what?
i may be a newbie but dont flame me......iver never delt with a civic before....
Old 01-20-2004, 12:17 PM
only ludes.....
Old 01-20-2004, 01:35 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
Re: Civic Hatch B16 swap? Hard or not?
i would bet there are probly at least 50 topics about this if you searched.
but anyways.
you need.
b16 engine+trans+ecu
teg axles
modifyed shift linkage
hasport or the crappy motor mounts
good idea to change the timing belt,water pump,
plugs, wires,clutch any other gaskets. they have been sitting there for a while so its a good idea to change them. you'll have to do it soon or later.
Old 01-20-2004, 01:51 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
do a search within this forum or stop by www.4thGeneratinCivic.com in the engine section for links.
but seriously...if you feel like you might be flamed, try running a search first. one of the only things you will be flamed for around here is not doing a search first.
for some reason people don't like repling to the same things 500 million times, go figure lol
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-20-2004, 07:43 PM
SiZ's Avatar
SiZ SiZ is offline
That swap is unpossible!
"The nympho of info, I'm fuckin' what ya heard"
Old 01-21-2004, 02:41 PM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
Re: Re: Civic Hatch B16 swap? Hard or not?
complete engine swap from HMO will come with everything you need.
you have to run four wires: vtec/oil pressure/knock/2nd 02. you will need to buy some mounts. i usually recommend hasport or hcp mounts. new linkage / new axles (90-93 integra usually). pr3 or pw0 obd0 ecu.
Julian
Old 01-21-2004, 02:59 PM
lilol89crx lilol89crx is offline
its a fairly simple ordeal if your fairly mechanicaly inclined. took us one day to install our b16 and get it up n running properly(full day). its more or less a drop in ordeal with a bit of wiring and hammering as long as you have all the required parts to do so.
92-95 hatch b16 swap and supercharge?? clevisR6 JDM Motor & Parts info/chat 3 07-22-2005 02:32 PM
89 civic hatch b16 for sale mjarrett '88 - '91 Civic | CRX | Wagon | Shuttlee 2 12-10-2003 02:34 PM
96 civic hatch engine swap ????? infamousracing Engineering/ Technical 2 05-21-2003 07:46 AM
96 civic hatch engine swap ?????? infamousracing '88 - '91 Civic | CRX | Wagon | Shuttlee 4 05-20-2003 09:08 PM
