Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-20-2004, 10:52 AM
W4R(HILD W4R(HILD is offline
Question Fan for heater/AC not working =/ ???
I got home from work everything fine, get back in Jeep the next day and the fan for heater isnt working. I hit the AC button and it lights up but still no fan. I can feel heat coming out of the vent once I start moving but its not nearly nuff to get ya warm. Its been like 17-30 for the most part here in VA the past week and any ideas are welcomed. Thanks in advance!!! cheers =P
Old 01-21-2004, 12:54 AM
Ive checked the fuses and now believe the problem lies in the relay switch...anyone know where this is located? Hope that its in a easy place to reach...ha...come on peeps help a brother out!!!
Old 01-21-2004, 12:59 AM
blasian_man's Avatar
blasian_man blasian_man is offline
i drive a different car, but mine is all the way behind the dash, i couldn't reach it or see it when i stuck my head in the footwell
Old 02-03-2004, 07:03 PM
tief tief is offline
warchild:
I had the exact same problem today. I took it to the dealer and he diagnosed it as a "melted connector on the blower motor" He wanted me to buy a new motor and connector assembly to the tune of $506.
So, I too would like to know where the blower motor is.
Old 02-05-2004, 07:01 PM
95Orvis 95Orvis is offline
Guys, on my 95 Orvis, the Blower and Resistor is under the passenger side dash. Both are within reach without too much dismantling but you will end up with a kink in yuor neck working on it. I just replied to a different post "Blower Motor" which has some additional detail regarding the resistor.
Good luck.
Old 08-22-2004, 04:27 PM
99bracketracer 99bracketracer is offline
Re: Fan for heater/AC not working =/ ???
mines not working either how hard is it to get to the blower motor assmbly?
Old 08-22-2004, 04:50 PM
DIY Mechanic DIY Mechanic is offline
The fan is so easy to replace it is not even funny.
3 screws and a plug. All right there – easy to get to.
Just above the passengers feet.
This is a junk yard part. I would not consider buying a new one.
The screws are offset so you cannot put it in wrong.
I did not look in my manual but the there are two relays in the fuse compartment by the passengers right foot and three under the hood in the electrical junction box.
Old 08-23-2004, 07:58 PM
come to find out ut wasnt the fan at all it was a burnt connector on the control module its a simple fix no money
99 GSE heater/AC not working, 35-60mph major shuddering ElementCrush Regal 2 10-02-2009 06:57 PM
Fan for heater and air will not work Ktallman Problem Diagnosis 5 12-15-2007 09:26 PM
Fan for heater will only work on level 3?? rwtcoburn S-10 8 01-28-2005 06:31 PM
fan for heat/ac not working momof2 Escort 1 08-21-2004 07:07 PM
