Old 01-20-2004, 06:38 AM
mdeverich mdeverich is offline
Erratic Temperature readings
Just installed a reman 350 5.7L in my truck, I am getting erratic temperature readings anywhere between 170- 230. Makes me nervous with a new engine. I'm guessing the temp sensor(it is the one from the old engine) Is there any other possibilities or could it be that simple just to change the sensor?
Thanks
Old 01-20-2004, 01:49 PM
michelq michelq is offline
Re: Erratic Temperature readings
you did not say what year this truck
Old 01-20-2004, 05:08 PM
comp comp is offline
more info,,, check for air pockets,and wire connections first
Old 01-20-2004, 08:48 PM
72 rs's Avatar
72 rs 72 rs is offline
things to check........thermostat, air pockets(unlikley), damaged wires leading to the sensor,'s. i would start with replacing the sensor.....not knowing the year of the truck u may have 2 of them. if its old it has one......normally in the head. if its a later model it has 2 one in the head and one in the intake somewhere (this one is in the fuel injected models, it sends info to the computer to help control fuel demand)
Old 01-21-2004, 05:55 AM
Lightbulb
Truck is a 1989 4WD. It does have the two sensors, one on the side of the block and the other by the gooseneck on the intake manifold. Looking at the sensor on the intake the plastic is broken where the plug goes in and the plug is not in good shape either. I'll change both sensors and the plug and see if that helps.
Thanks
Old 01-22-2004, 06:43 AM
Question
Installed new sensors and thermostat(Thermostat is a 190Deg). Going by the temp gauge the thermostat doesn't open until it hits about 250deg, then drops and holds steady at 215deg. I took a thermometer and did a check in the radiator and it was reading 170deg. This tells me that the gauge in the truck is off by 45deg.
Not sure whats going on, was thinking I could hook up a mechanical gauge to the block sensor and get a accurate reading. Never heard of the gauges being off like that. (electronic type)
any ideas?
Old 01-26-2004, 07:18 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
any ideas?
the 2 wire intake mounted sensor is the ECT/CTS - it feeds the ECM. hook up to a scan tool and then you can see what it is thinking if you select data stream output. the 1 wire in the side of a head or block is the gauge - they tend to corrode and they jump all over on those junk chevy gauges.
First use a scan tool to determine actual temp, if you feel it is off, grade it with a temp sensor - one of the IR type
if this is ok, then go after fixing the other one.
Old 05-24-2004, 06:24 PM
eagle12 eagle12 is offline
If you are using a seal that goes around the thermosat instead of a gasket for the housing outlet, that will stop the seepage which is supposed to happen so that the thermostat recognizes newer hot coolant instead of the colder pocket of coolant. I use the seal but I drill a 1/8" hole to help it act as if the seal wasn't there and I HAVE NO PROBLEMS NOW> I may try 2 holes a I think it is still too slow.
Old 05-24-2004, 07:51 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
any ideas?
try changing the sending unit first. Its located on the drivers side head, don'st cost very much and is pretty easy to do. If the guage still fluctuates, then something has happened to teh guage and the only way to fix it is to send the entire cluster off. You could buy a manual temp. guage and then you would have a true reading. My truck did the same thing about 2 years ago. The temp. guage started going to about 250 or so and then back to normal and then finally just pegged out. Changed the sending unit and it started fluctating from normal to about 240, changed thermostat and water pump before we found it was the guage. Hooked a manual temp. guage up and now the truck stays right on 190 degrees.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 05-25-2004, 11:37 AM
pind pind is offline
I have found that even with manual gauges, I run the probe into the intake manifold on older trucks, just to the left side of the t-stat housing. the temp on the manual gauge, when using a 185 stat, will climb to about 230 before the stat opens and allows coolant to circulate. at first this caused some concern, but after using auto meter, stewart warner, and various other brands of gauge, just to compare, they all do the same thing.
Old 05-25-2004, 01:19 PM
Re: Re: Erratic Temperature readings
Well, that sounds like somethign else is wrong then in your case. Mine never makes it above 190 or close to it before the stat opens. And the only time it gets above the 190 mark is when its hot out, got the a/c on and pulling a hill, adn then it just goes to 210.
**1966 Chevy II**
Old 05-25-2004, 05:59 PM
Cold pocket of coolant can't reach the thermostat if seepage isn't allowed to go past the thermostat. Is your thermostat floating in the outlet housing or sealed at the thermostat flange by a rubber seal? Remove it and just rely on the housing gasket or rtv to allow the needed seepage. Let us know.
Old 05-25-2004, 06:10 PM
broughy84's Avatar
broughy84 broughy84 is offline
My truck heats up to 210 before the stat opens and then it runs around 180-190
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Erratic temperature gauge readings markqc Venture 7 03-26-2010 06:31 PM
Video of erratic temperature gauge tell me what's happening ***video*** mtndew568 Aurora 1 10-07-2009 02:40 AM
Erratic Temperature gauge bholloway C/K 0 05-31-2005 08:23 AM
Erratic Temperature Gauge and Tachometer udengineer2001 Intrigue 1 02-22-2005 12:03 PM
Erratic Temperature Guage, (95 JGC V8) gorim Grand Cherokee | Grand Cherokee SRT8 1 12-11-2004 06:46 PM
