Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 01-20-2004, 12:07 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
correct times..
http://2ndgenrx7.freeservers.com/performance.html
I found this page and was wondering if you all thought most of the 1/4 and 0-60 times were right... most of what I saw looked right give or take .2 seconds, but you can give or take .2 seconds just with different drivers so I'd say most of it is good info
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 01-21-2004, 08:32 AM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Re: correct times..
The 98 NSX numbers seem a bit off...4.5/12.9 in quarter?
The 90 TSi AWD numbers are off...it should be alot quicker than 8.0 seconds in the 60 dash...and then faster in the quarter...it weighes less than the 2nd Gen and has the same motor...and in most cases was more reliable and stronger
No such thing as a 240SX SE-R
I think the 90 Celica GTS Turbo (the All Trac) I believe was faster than what they say 7.8/15.8...more like low 7's and low mid 15's
Yours truly,
Gabriel
Old 01-21-2004, 09:41 AM
quarter_mile's Avatar
quarter_mile quarter_mile is offline
skyline time is .5 seconds faster then it really is from what i can gather.
Old 01-21-2004, 11:58 AM
nacho_nissan nacho_nissan is offline
Send a message via AIM to nacho_nissan Send a message via MSN to nacho_nissan Send a message via Yahoo to nacho_nissan
Re: correct times..
no,its always down to the track and driver...
Old 01-21-2004, 02:08 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
Times can also vary depending on altitude, try to keep that in mind. A high 12 second car at sea level, could be running mid 13s on higher elevation all day.
Old 01-22-2004, 02:37 PM
Pennzoil GT-R's Avatar
Pennzoil GT-R Pennzoil GT-R is offline
Re: correct times..
yeah the skyline is a little optimistic.
i also think a GTS-R is abit quicker than 4.2 0-60.
Old 01-22-2004, 03:25 PM
Soyo's Avatar
Re: correct times..
ok cool, not that concerned about it anyways... but pennzoil gt-r I have a question abotu your sig, you do know that bhp mean Base Horse Power right? where you gonna find a skyline with 1000 Bhp? maybe you meant whp for at the wheels horsepower or Fhp for flywheel horsepower... just checking
Old 01-22-2004, 07:33 PM
Mr Payne Mr Payne is offline
Re: correct times..
bhp does not mean "base horsepower"...
Old 01-22-2004, 08:53 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: correct times..
bhp means brake horsepower. and brake horsepower in lamens terms is horsepower at the wheels. what do u mean by "base horsepower" soyo, if there is such a thing. and i have heard of skylines having 1000 bhp.
ZedEx Crew Member #2
Old 01-22-2004, 10:00 PM
Re: correct times..
bhp does not mean horsepower at the wheels either.
Old 01-22-2004, 10:13 PM
Re: correct times..
then what is bhp?
Old 01-23-2004, 01:12 AM
Kurtdg19's Avatar
actually, brake horsepower (bhp) is the usable power at the engine crankshaft. It pretty much got this name because they first used a prony brake to measure crank horsepower. Brake horsepower is the same thing as crank horsepower.
Old 01-23-2004, 01:13 AM
s15ilvia's Avatar
s15ilvia s15ilvia is offline
Send a message via AIM to s15ilvia
re: bhp
i always thought brake horsepower was the amount of force the engine exerts on a brake but ive heard alot of different explainations
Old 01-23-2004, 06:56 AM
Re: correct times..
i heard that brake horsepower is the readout on a dynometer. and i have looked at a few definitions and they have said that it is measured at the drive shaft.
Old 01-23-2004, 06:47 PM
Kurtdg19's Avatar
Re: Re: correct times..
Yes a engine dynometer is used to measure brake horsepower. Usually by an electric motor or a fluid coupling is used to create a drag on the crankshaft to find its output.
A chasis dynometer measures drive wheel hp.
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
timing marks/balancer Top Dead Center thehustler211 Problem Diagnosis 1 03-28-2009 11:31 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
Anyone know the correct timing iceman8124 GV/GVS/GVL 1 12-02-2005 02:54 PM
Correct Timing for 5.7 Vortec 1997 roadtrip120 Engineering/ Technical 5 02-16-2004 10:18 AM
