Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-19-2004, 11:44 PM
panicx panicx is offline
Exclamation intake backfire 1989 gmc 7.4 tbi
My truck runs great untell it warms up.
Then ( seems intermentent )starts to backfire through the tbi.
Things i had tryed ,
plugs,wires,cap rotor,reman dist.
The only code i ever got was for the tps,replaced it with no change.
any ideas ?
Kelly
Old 01-20-2004, 12:31 AM
herefordman herefordman is offline
Re: intake backfire 1989 gmc 7.4 tbi
Sounds like still a timing issue, distributor in right and timed right ? maybe a bad coil ?
Old 01-20-2004, 08:35 PM
Hmm..well i did....
Well I did run the base timing up to 8 btc,calls for 4 btc.
But advancing it helped it not to backfire as much.
Set at 4 btc it will not hardly pull out of the driveway.
panicx
Old 01-22-2004, 08:38 PM
Sounds to me like the distributor is worn out and moving around when it spins, missing the plug wire terminals occasionally when it fires.
1990 C3500 7.4L TBI backfire nvr2nd Sierra 1 12-09-2010 07:10 AM
1989 Gmc Sonoma 4.3 Spitting and Sputtering problem. lahhavox Problem Diagnosis 2 06-11-2009 02:56 PM
Timing Question 94 C3500 7.4 Dually TBI trcrumb C/K 8 01-22-2005 03:38 AM
91 GMC Sierra 4.3 TBI wstanley C/K 3 12-27-2004 04:19 PM
GMC 1995 4.3L VIN "Z" TBI Rough Idle & Exhaust Smell skblades Sierra 0 09-05-2003 11:55 PM
