I am interested in buying a 2000 camaro in june. Till then im just doing a bit of research. But as the camaro options are off course no longer listed on the chevrolet website its a little hard to find credible information on what comes stock on a camaro.
My question is if anybody can list the stock features of a 2000 ss camaro and also of a 2000 z28. For anybody that answers , thanks in advance. |
Re: 2000 Camaro stock ?
um, well, are you talking about the base level options or what??? like what would you get if you didnt check any boxes and just said, give me a camaro, or are you asking for ALL available options that you could have had from the factory?????
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
Year 1998
Origin St. Therese; Quebec Canada Make Chevrolet Base Price $20,470 USD Model Camaro SS Coupe Configuration V8 Curb Weight 1524 kg / 3360 lbs Valvetrain OHV 2 Valves / Cyl Length 4915 mm / 193.5 in Displacement 5666 cc / 345.8 cu in Width 1882 mm / 74.1 in Power 238.6 kw / 320.0 bhp @ 5200 rpm Height 1303 mm / 51.3 in Torque 467.8 nm / 345.0 ft lbs @ 4400 rpm Wheelbase 2568 mm / 101.1 in Bore 99.0 mm / 3.9 in Front Track 1542 mm / 60.7 in Stroke 92.0 mm / 3.62 in Rear Track 1539 mm / 60.6 in Redline 6000 rpm Steering Rack & Pinion w/ Power Assist HP / Liter 56.48 bhp per litre Body Frame Unit Steel w/ Composite Panels Front Brake Size 300 mm / 11.8 in Rear Brake Size 302 mm / 11.9 in Rear Brakes Vented Discs w/ Vacuum Assist & ABS Front Brakes Vented Discs w/ Vacuum Assist & ABS Front Wheels F 43.2 x 22.9 cm / 17.0 x 9.0 in Rear Wheels R 43.2 x 22.9 cm / 17.0 x 9.0 in Front/Rear Tires F 275/40ZR-17 Gear Type T56 6-Speed Manual OR 4L60E 4sp AOD 1st Gear Ratio 2.66:1 2nd Gear Ratio 1.78: 3rd Gear Ratio 1.30:1 4th Gear Ratio 1.00:1 5th Gear Ratio 0.74:1 6th Gear Ratio 0.50:1 7th Gear Ratio Not Available Final Drive Ratio 3.42:1 Performance Top Speed 257.5 kph / 160.0 mph 0 - 60 mph 5.5 seconds 0 - ¼ mile 13.9 seconds 0 - 100 mph 13.2 seconds Lateral Acceleration 0.87g EPA City/Hwy 18 / 27 mpg
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
Here are just some interior options i can think off the top of my head-
Leather wrapped steering wheel leather wrapped shifter AOD 4SP Hurst shifter w/ 6-spd leather seating monsoon c/d player Standard delco casette 7-speaker option t-tops 12 disc cd changer sterio controlls built right into the steering wheel exterior: -RS Bodykit for Z28 -SS-5 spoke 17x9 or 10 spoke 17x9's -Z28-5 spoke 16x8 -SS Spoiler -SS Hood -SS Badging Suspension SLP Tie rods and stabilizers Larger brakes performance SLP 3" Slash cut exhaust tips
i think 13.9 is a bit slow LOL
www.automotiveforums.com |
It all depends. The test car was a 6 sp (not such a good driver?) and maybe they tested it in colorado?
