Old 01-19-2004, 04:27 PM
ccandtc ccandtc is offline
GTP electrical
New member here with some electrical problems. The 10amp interior light fuse on my 2000 GTP keeps blowing. Have checked some of the obvious things, but am really lost. I don't want to take it to the shop if I don't have to. Any suggestions on how I can wring this out? Thanks!
Old 11-12-2004, 06:16 PM
sscrash sscrash is offline
Re: GTP electrical
Im having the same problem with my 2000 GTP...have you found anything out??
Thx
Ed
Old 11-12-2004, 08:20 PM
dwalmop dwalmop is offline
Re: GTP electrical
something is shorting somewhere if you've checked the obvious and found nothing. You're probably going to have to chase the wiring to find the problem.
Old 11-12-2004, 09:15 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: GTP electrical
Do either of you have sunroofs??
ClubGP Member 6530
Since 2001
Old 11-13-2004, 09:29 AM
Re: GTP electrical
Yes I have a sunroof
Old 11-13-2004, 09:35 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: GTP electrical
Have to give Big-L a little time to get out here. He works a little late. But when he does, he'll have the right anwser.
Old 11-13-2004, 06:30 PM
Re: GTP electrical
No prob....Im glad to be here
Thx
ss
Old 11-13-2004, 08:32 PM
BIG-L's Avatar
Re: GTP electrical
Does the bulb burn out when you first install it or does it take a few days??
ClubGP Member 6530
Since 2001
Old 11-13-2004, 08:51 PM
Re: GTP electrical
I told the guy you would have the answer. Now your making him wait? I was going to run an ad in the local paper, for you to reply to car problems. Not any more. Only kidding. It's in the Tampa paper. Told them to call you collect.
Old 11-14-2004, 05:55 PM
Re: GTP electrical
It lasts a few days or more...
Thx
Ed
Old 11-14-2004, 10:27 PM
BIG-L's Avatar
Re: GTP electrical
I heard of problems with a slight water leak on some of the 97/2003 w/sunroofs and that might be the problem and shorting out the bulb.
ClubGP Member 6530
Since 2001
Old 11-15-2004, 05:28 AM
Re: GTP electrical
Big L ...I put in a 20amp fuse and it seems to be lasting for now???Instead of the 10amp
Old 11-15-2004, 10:17 AM
BIG-L's Avatar
Re: GTP electrical
Id try and drop it down to a 15 amp and see if that works.....you have a problem some where and the 10amp fuse keeps blowing because of a short and that is about the max for the wires,with a 20amp you are just covering up the problem and there could be a chance that it will get the wires to hot and burn some stuff up.So give a 15amp a try,because you are still covering it up but it wount get the wires as hot as the 20amp fuse .
ClubGP Member 6530
Since 2001
Old 11-15-2004, 06:10 PM
Re: GTP electrical
Thx Big L ..Ill give it a try and post back the results
Ed
Old 11-16-2004, 02:59 AM
empathydude empathydude is offline
Send a message via AIM to empathydude Send a message via Yahoo to empathydude
Have you tapped anything else electrical into ANY of the light/accessory plugs? I had the problem when I first added more lights off hte existing string and then again when I plugged a 500w power inverter into the cig plug...
http://members.cardomain.com/empathydude
Put an extra set of neon lights on your car, they make you go faster. =)
