Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 01-19-2004, 01:18 PM
thegooch49 thegooch49 is offline
A/C bulb out, how to replace?
Hi, I belive I have a burnt bulb on the A/C instrument panel. I have no lights for the fan, temperature, or direction. They all went out at the same time. Is there one bulb that runs all 3? Could it be a blown fuse instead? I read in a previous post that it's most likely the bulb, and to replace it. How do I get at it? Do I need to remove one of the dials? If so, which dial do I remove, and how do I do it?
Thanks for the help.
Jefff
2000 Jetta GLS
Old 01-21-2004, 01:29 PM
skiinganna skiinganna is offline
It's pretty easy. It's one bulb behind the middle dial. With a pair of pliers, pull out the middle dial. Pull the bulb out with a pair of needle nose pliers (careful not the break it...cuz I did). Replace that bulb and you are good to go.
Anna
2000 1.8T Jetta
Old 01-23-2004, 04:12 PM
unamazza unamazza is offline
Re: A/C bulb out, how to replace?
Hi. I have the same problem. Would this solution also apply to a 1995 Jetta? Thanks.
Heater knob bulb replacement - 93 geschaef Camry/Camry Hybrid/Vista 2 02-16-2010 01:54 PM
2001 License Plate Bulbs Delawn Interior | Exterior | Appearance 5 07-31-2009 10:29 PM
Blower went out! How to replace, or is it just "resistor" lup Alero 11 03-11-2007 11:23 AM
How the heck do you pull the headlight bulbs out?!! GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 13 05-11-2005 12:27 AM
CD Player Lighted Display Out. How replace bulb? Hamfiles Explorer | Explorer Sport Trac 1 12-21-2004 09:00 PM
