Old 01-19-2004, 12:55 PM
Goatroper Goatroper is offline
Won't Start?
I ran into this problem with my '91 4.0L....would not start. Found the rotor tip completely gone, the inside of the dist cap looked like a sewer pipe. After changing the rotor, dist cap and coil....still would not start. The wire leading from the coil to the dist was bad. I've done shade tree mechs for years and this is the very first time I've ever come up against this.
GR
Old 01-20-2004, 10:35 AM
comp comp is offline
the basic's: it has to have, fuel,air,spark,& compression, check or replace to get spark, do you smell gas??? can you find out why rotor
came apart? to get you going
Old 03-12-2004, 12:08 PM
Re: Won't Start?
The problem was the crankshaft position sensor.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
99 Regal LS stalled now won't start mfraumeni Regal 7 04-05-2010 12:38 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 09:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
