Old 01-19-2004, 11:02 AM
huminski's Avatar
huminski huminski is offline
2004 5.3 Muffler / Exhaust Pipe Diameter
Hi,
Does anyone know for certain what the inlet and outlet sizes are on the factory muffler. I measured the pipe at the exit (across the opening) and it is 2.75"OD. I don't have a caliper so it's hard to measure it anywhere but across the end opening. My local shop has Flowmaster 40 and 50 series but only in 2.50" or 3.00". Does the factory pipe flare out from 2.5 to 2.75 at the tip or is the entire system 2.75? I just want to cut out the factory muffler and replace with a flowmaster, retaining the rest of the factory stainless system.
Thanks!!!
Steve
2004 2WD 5.3 Xcab StepSide
Old 01-20-2004, 07:17 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: 2004 5.3 Muffler / Exhaust Pipe Diameter
The exhaust shop should not have any problem fitting a flowmaster in the stock location, IF they know what theyre doing. THe shop where I used to work at, if the pipe was 2.75, then I would use a 2.5" muffler and slip it inside the stock pipe.
Old 01-21-2004, 08:56 AM
huminski's Avatar
Thanks. That would create a little extra restriction I would think, but it would work. Regardless, I bit the bullet and ordered the Gibson super truck system. I had the ExtremDuals on order, but I saw a few pics of them actually installed and it wasn't the look I thought it would be. In my opinion you could see way too much of the pipes. My dad had the super truck system on his 1998 Ram 1500 and it sounded really good, it's loud which is what I'm looking for and it looks different. If it was legal I would just run a straight pipe but I need to pass inspection, ya know?
Thanks again!
Steve
Old 01-21-2004, 09:17 AM
BigRed04Silverado BigRed04Silverado is offline
I just recently had the 40 series with 2.5 pipes put on my 04 5.3. It sounds great, almost a little to loud and performance seems a bit better but nothing drastic.
Red 04 Silverado 1500 4x4
6'' FABTECH Full Suspension Lift
BFG TA KO Tires
American Racing Dimond Series wheels
Flow Master 40 Series dual with 18'' stainless slash cut tips
Drop in K/N
Tinted Windows
exhaust pipe diameter question birar SC/SL/SW 2 09-21-2009 05:12 PM
metro exhaust pipe diameter? fjb123 Metro 1 03-01-2009 10:03 AM
Exhaust piping diameter genkichild Integra 5 06-27-2005 02:05 AM
Exhaust pipe diameter Esky Engineering/ Technical 9 12-18-2004 08:13 AM
exhaust pipe diameter GScivic7 CL | Inspire | Saber | TL 0 09-29-2002 08:53 PM
