Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-19-2004, 10:54 AM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
Ideal compression ratio?
what is the ideal compression ratio for a ride with 14 psi to have it a daily driver? Or just to run 14 psi safely
Old 01-19-2004, 12:29 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would say anywhere between 8:1 and 9:1.
Old 01-19-2004, 08:34 PM
454Casull 454Casull is offline
Re: Ideal compression ratio?
The ideal compression ratio? As high as possible, of course.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 01-20-2004, 03:41 PM
SaabJohan SaabJohan is offline
A little above 9:1 should be possible with a good engine.
Old 01-20-2004, 04:00 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
as much as you can withou detonation
Mustangs are nice, but I'd rather have one of these...
Old 01-23-2004, 12:40 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
i would use a 8.0-.5:1 compression radio if i was running boost, at that you would be safe from detionation and leave some head romm for more boost later or if your low on money gas prices are high and you can't afford 92-97 octane drop the boost and run on 84 (does that idea work?)
Old 03-01-2004, 09:25 PM
ToP cAt ToP cAt is offline
Send a message via AIM to ToP cAt
Unhappy I have always been clueless on this topic!!
I have always read about or heard about this thing called a compression ration!! i really dont have any clue as to what it really means. Is there anyone out there who can help me???
red impact 5
The one, The only, ToP cAt!!!
Old 03-01-2004, 09:42 PM
2turboimports's Avatar
2turboimports 2turboimports is offline
it;s just the ratio of air that enters the cylinder for every stroke. 8.5:1 ,for every 1 stroke, 8.5 times the volume of the cylinder enters. at least this was my understanding.
then there's staitc and net compression. static is the compression of the piston and everything ONLY. When you add boost you up the compression b/c air is being forced in, forced induction. Pump gas and ample tuning is supposed to make somewhere around 12.5:1 the MAX static CR for an NA car. Although there are badasses out there who can run 15:1 and hjigher NA drag motors.
Old 03-01-2004, 09:56 PM
I feel relieved!!
Thanks alot man, you sure have helped me out alot on this topic.
red impact 5
Old 03-01-2004, 10:04 PM
ahh, shit i have spotted errors....while that's the general jist...the compression ration of a piston means that for every 1 stroke it COMPRESSES 8.5 or whatever the amount of air that many times. So 12:5:1 is extremely high to be running around with.
Old 03-03-2004, 04:22 PM
Compression ratio is the volume of the cylinder when the piston is at the bottom divided by the volume of the cylinder when the piston is at the top.
Old 03-16-2004, 05:53 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
how high until you breach 91 octane?
Old 03-29-2004, 12:17 AM
boosted331 boosted331 is offline
Re: Re: Ideal compression ratio?
Theres about a thousand variables that effect this, so you really can't answer this. From simple ones such as inlet air temps and the compression ratio of your motor, to bore size, quench area, spark plug position, cam specs, etc, etc, etc, they all effect how much boost you can run.
Old 03-30-2004, 03:27 PM
RocketDSM RocketDSM is offline
Compression ratio shown so everyone can see it without question -
Volume of Cylinder with piston at bottom = 100ci
Volume of Cylinder with piston at top = 10ci
Copmression Ratio = 10:1
As for what compression to run with a particular boost - too many variables to reasonable answer this. I'm one that like high compression engines for the broader torque curve. I run 9:1 at 12psi on 91oct. With better gas I can handle 15psi without detonation problems. If you have a really good engine management system onboard, you can push 9:1 at 14psi on 91oct with no worries. You would need a full standalone and lots of tuning time, but it could be done safely. If you are on a stock ECU, keep it to 8.5:1 or even lower. My examples use 91oct because that is all I have in my area so that is all I can honestly do comparisons with.
Old 04-05-2004, 11:32 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
Pretty much as what they all said. Compression ratio determines how much air-fuel mixture is pressurized. A ratio of 9:1 would mean that the maximum cylinder volume is nine times the amount as the minimum cylinder volume. When you have a power adder such as a turbo or supercharger, lower compression allows more fuel charge into the cylinders..
compression ratios and method of compression SPOOK(I) Impreza/9-2x/Outback Sport 2 05-28-2013 06:26 PM
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
ideal compression ratio unknownluder69 Prelude 3 02-26-2005 03:48 PM
Compression Ratios....drift..your sarcasm welcome hehe VTEC_boi Engineering/ Technical 16 03-18-2004 06:30 PM
compression ratio b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-23-2002 12:47 AM
